mirek Posted April 20, 2021 Posted April 20, 2021 Please help, I have an XPL 3000 that will not update, I tried resetting it back to factory, I setup network but still does not update ever. BuzzTV XPL 3000 Android security patch stuck on Aug 1 2016 ver Android 6.0.1 build V001s901_20190314 Kernl Ver 3.14.29 I'm up in Canada is this blocking me ? also is there a place i can download the files onto USB stick that is safe, so i can try this method. thank you Quote
nbs. Posted April 20, 2021 Posted April 20, 2021 What is buzz version number?menu configuration at bottom Quote
nbs. Posted April 21, 2021 Posted April 21, 2021 (edited) 2.0 352 if Emory serves me correctly Tere are no other updates Edited April 21, 2021 by nbs. 1 Quote
shaime Posted April 30, 2021 Posted April 30, 2021 I did factory reset of buzz tv and now it's not updating. It's version is 1.6 (162): 08/07/2018 Also "organize categories" option is also not available. Quote
shaime Posted April 30, 2021 Posted April 30, 2021 Ok so I have downloaded the file. I am new here so can you please let me know how to install the file? Quote
nbs. Posted May 1, 2021 Posted May 1, 2021 (edited) install file onto usb stick ,insert into buzz and go to appinstaller in apps Edited May 1, 2021 by nbs. 1 Quote
Shekhar Posted July 8, 2021 Posted July 8, 2021 Hi, could you also send the update file to me? I am also in Canada and update always fails for me. My buzz tv version is also 1.6(1.6.2) Updated 08/07/2018. Device: BuzzTV XPL 3000 Android: 7.1.2 build: V002S901_20180906 Quote
