Sidney81 Posted August 11, 2021 Share Posted August 11, 2021 I notice the xrs 49000 doesn't have auto frame rate switch option in settings. Is there going to be an option for this in a new firmware update. ? As I'm getting a juddery playback with live TV. Quote Link to comment Share on other sites More sharing options...
dishuser Posted August 12, 2021 Share Posted August 12, 2021 have you tried the other player? Quote Link to comment Share on other sites More sharing options...
Sidney81 Posted August 12, 2021 Author Share Posted August 12, 2021 Iv tried the other player plus tivimate premium. I have a ugoos box which plays perfect. And has the afrd option in its settings. And cost half the price. Considering the buzz box is high end value I would of expected afrd in its firmware surely. Quote Link to comment Share on other sites More sharing options...
nbs. Posted August 12, 2021 Share Posted August 12, 2021 (edited) so you diagnosed the issue as auto framerate? You say you tried tivimate and stream isnt smooth? Tivimate has auto frame rate Maybe its a server/box conflict I suggest you try and troubleshoot your issue before you start bashing the box Edited August 12, 2021 by nbs. Quote Link to comment Share on other sites More sharing options...
Sidney81 Posted August 12, 2021 Author Share Posted August 12, 2021 (edited) I suggest u read up on technology mate. If the box can't switch auto frame rate as its not implemented in the firmware. Then it won't switch regardless if the tivimate has the option or not. Dear me Like I said I paid £70 for ugoos box and playback is much smoother as it has afrd. Edited August 12, 2021 by Sidney81 Quote Link to comment Share on other sites More sharing options...
nbs. Posted August 12, 2021 Share Posted August 12, 2021 I have never seen a complaint about the stream being off due to the box not having auto frame rate but since you have determined thats your issue there is not much advice to give you Here is an answer to your question Quote Link to comment Share on other sites More sharing options...
lailanis Posted August 12, 2021 Share Posted August 12, 2021 Auto refresh rate isn't implemented in buzz, I mentioned that months ago, they may or may not add it Quote Link to comment Share on other sites More sharing options...
Sidney81 Posted August 12, 2021 Author Share Posted August 12, 2021 It should be implemented though. For the price it's selling for it should be there. Nidvia shield only slightly more and has it. Like I said in previous post I have cheaper devices which has it. Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted August 12, 2021 Share Posted August 12, 2021 20 hours ago, Sidney81 said: I notice the xrs 49000 doesn't have auto frame rate switch option in settings. Is there going to be an option for this in a new firmware update. ? As I'm getting a juddery playback with live TV. Yes Auto Frame Rate will be added to the 4900 + all other Buzz models running Android 9 on our next update Its currently being tested. It will be available through Buzz Utilities and work on the entire OS, not just the Buzz app. 1 Quote Link to comment Share on other sites More sharing options...
Sidney81 Posted August 12, 2021 Author Share Posted August 12, 2021 1 hour ago, allaboutbuzz said: Yes Auto Frame Rate will be added to the 4900 + all other Buzz models running Android 9 on our next update Its currently being tested. It will be available through Buzz Utilities and work on the entire OS, not just the Buzz app. Ah that's good news. Quote Link to comment Share on other sites More sharing options...
DRAG00N519 Posted August 12, 2021 Share Posted August 12, 2021 2 hours ago, allaboutbuzz said: Yes Auto Frame Rate will be added to the 4900 + all other Buzz models running Android 9 on our next update Its currently being tested. It will be available through Buzz Utilities and work on the entire OS, not just the Buzz app. with the amount of changes and improvements that are going to be included in this next update it sounds like you might have to rename the box the XRS 5000 lol 1 1 Quote Link to comment Share on other sites More sharing options...
Maestro701 Posted August 13, 2021 Share Posted August 13, 2021 4 hours ago, DRAG00N519 said: with the amount of changes and improvements that are going to be included in this next update it sounds like you might have to rename the box the XRS 5000 lol I think it might be enough to take it to XRS6000 1 1 Quote Link to comment Share on other sites More sharing options...
Ryu Posted August 13, 2021 Share Posted August 13, 2021 or we might call it box of 2021 1 Quote Link to comment Share on other sites More sharing options...
DRAG00N519 Posted August 13, 2021 Share Posted August 13, 2021 5 hours ago, Ryu said: or we might call it box of 2021 We have to see what the update looks like first but as of right now there's not a box that has come out this year that compares to the 4900 1 Quote Link to comment Share on other sites More sharing options...
Ryu Posted August 13, 2021 Share Posted August 13, 2021 6 hours ago, DRAG00N519 said: We have to see what the update looks like first but as of right now there's not a box that has come out this year that compares to the 4900 thats why it should be box of 2021 Quote Link to comment Share on other sites More sharing options...
DRAG00N519 Posted August 14, 2021 Share Posted August 14, 2021 21 hours ago, Ryu said: thats why it should be box of 2021 I've had issues with my box from day one so that's why I said we have to see what the update looks like first 1 Quote Link to comment Share on other sites More sharing options...
A C Posted August 15, 2021 Share Posted August 15, 2021 I purchased another box, i should have waited. Thinking of return when it's delivered monday. Quote Link to comment Share on other sites More sharing options...
Ryu Posted August 15, 2021 Share Posted August 15, 2021 1 minute ago, A C said: I purchased another box, i should have waited. Thinking of return when it's delivered monday. why do you want to return it? whats wrong with your first box? I have zero issues with mine and im beating it a lot since I own it and still working great. Quote Link to comment Share on other sites More sharing options...
A C Posted August 15, 2021 Share Posted August 15, 2021 1 minute ago, Ryu said: why do you want to return it? whats wrong with your first box? I have zero issues with mine and im beating it a lot since I own it and still working great. Having lots of buffering and i have another cheaper box with no problems, i wanted this box to brag and show off. Quote Link to comment Share on other sites More sharing options...
nbs. Posted August 15, 2021 Share Posted August 15, 2021 sometimes there are server/box conflicts They can be resolved but buzz need info to fix any issues what have you done? Quote Link to comment Share on other sites More sharing options...
A C Posted August 15, 2021 Share Posted August 15, 2021 16 minutes ago, nbs. said: sometimes there are server/box conflicts They can be resolved but buzz need info to fix any issues what have you done? I used the service app and it's fine. I'm going to delete my post because i want this to the box #1. Hurry with the update!!! Quote Link to comment Share on other sites More sharing options...
nbs. Posted August 15, 2021 Share Posted August 15, 2021 3 minutes ago, A C said: I used the service app and it's fine. I'm going to delete my post because i want this to the box #1. Hurry with the update!!! the service app is not the buzz software Quote Link to comment Share on other sites More sharing options...
A C Posted August 15, 2021 Share Posted August 15, 2021 (edited) 4 minutes ago, nbs. said: the service app is not the buzz software That was the test, before using the service app. Delete my post Edited August 15, 2021 by A C Quote Link to comment Share on other sites More sharing options...
nbs. Posted August 15, 2021 Share Posted August 15, 2021 That doesn't prove anything Quote Link to comment Share on other sites More sharing options...
