Losing Sound
TheGhost
Ok now before you try and blame the service it isn't the service for
this issue.
Basically what happens is the sound just randomly cuts out on my buzz tv
box only. Now I have my providers app as well and when the sound cuts out on
my TV using my BuzzTV box the sound is perfectly fine still on their app and
doesn't cut out. This isn't an issue with the provider because it only happens
on the BuzzTV box!
Basically what happens is the sound just randomly cuts out and I still have video
but no audio and then it just randomly comes back again.
This is most definately an issue with the BuzzTV box itself.  Please fix this
immediately.  As I said the sound stays on and works perfectly on their app
when I am watching it at the same time with my tablet but cuts out
on my buzztv box so I have NO sound what so ever on my buzz TV box.
This is annoying you need to fix this.  This is most definately an issue with
the BuzzTV box because the sound works perfectly on their app or even Perfect
Player on my tablet using either one.  But on BuzzTV the sound randomly
cuts out and it isn't just one channel either it does it randomly on various channels.
This is again an issue with the BuzzTV box and NOT the provider.
this issue.
on the BuzzTV box!
Please PM me
  • 2 months later...
Running the xr 4900 same sound lost !! Go up a channel and back then ok for a bit. Some days no problems other days it’s bad.
Running a different brand of box and it’s 7 years old no problems on sound loss
it the player,  a bug of some sort
I have no sound issues on the 4900 using same service with secondary player
Edited by nbs.
10 hours ago, DRAG00N519 said:
That happens to me when I use the default player and then when I switch to the secondary player some streams lag
I experience this both on the 4900 and 3000 using secondary player on wickediptv. It must be a codec issue but I love my secondary player, always have lol
I'm using a completely different app for my IPTV service and everything's working perfectly so there must be a issue with both players to be fair I have the same issue when I use OTT navigator which is another IPTV app right now I'm using IP TV extreme pro
Correct secondary player ok for sound but the pic will lock up on secondary
am on default player
it’s hit and Miss or really bad some days
I know it’s the server end for glitches etc
but the other brand no sound loss
Thanks
36 minutes ago, nbs. said:
It was posted elsewhere that the sound issue was not present on a different portal on your service
Try p3
My service doesn't allow m3u and if I use the Mac portal my service is locked on one device and I want to use multiple devices so I can't do that
  • 6 months later...
This issue is still occurring on December 19 2021 I am still getting the
same issue that I reported way earlier this year this issue still isn't fixed.
I am running the latest firmware and it still isn't fixed..
Current Firmware Version: V200211111\
Current IPTV  Version 4.0.522
So this issue isn't still solved even with the most recent
Firmware.
Firmware.
what did allaboutbuzz say when you messaged him?
