Ed B Posted March 13, 2021 Posted March 13, 2021 (edited) I've tried several SATA, SSD drives and USB drives formatted as NTFS and exFAT, even tried deleteĀ volume and let the XRS4900 formatĀ each drive. In every case I am unable to create folders or copy files to the drives. I've been trying to figure this out all day and no luck. The goal is to add a 1TB SSD drive to use for PVR recordings and media storage only. If it's not possible with the internal SATA port, I have a Seagate 1TB external USB 3.0 drive that I can use instead. If anyone has any ideas for me to try or a link to a guide, I would really appreciate any help! Edited March 13, 2021 by Ed B typo Quote
allaboutbuzz Posted March 13, 2021 Posted March 13, 2021 7 minutes ago, Ed B said: I've tried several SATA, SSD drives and USB drives formatted as NTFS and exFAT, even tried deleteĀ volume and let the XRS4900 formatĀ each drive. In every case I am unable to create folders or copy files to the drives. I've been trying to figure this out all day and no luck. The goal is to add a 1TB SSD drive to use for PVR recordings and media storage only. If it's not possible with the internal SATA port, I have a Seagate 1TB external USB 3.0 drive that I can use instead. If anyone has any ideas for me to try or a link to a guide, I would really appreciate any help! Can you record to the Drive still? Quote
Ed B Posted March 13, 2021 Author Posted March 13, 2021 3 hours ago, allaboutbuzz said: Can you record to the Drive still? No, not even with just the default 128GB drive. The recordings are listed in PVR folder, but files appear to be missing and won't play. Ā Quote
Ed B Posted March 13, 2021 Author Posted March 13, 2021 (edited) I can see all of the shows I set to record, but when I click on them it says ""No recordings found" This is with Recordings storage location set to Internal shared storage. Edited March 13, 2021 by Ed B Added info Quote
Juanita32022 Posted March 20, 2021 Posted March 20, 2021 Inserted 1Terabyte Samsung EV 600 drive as RemovableĀ Ā I am unable to create folders or copy files to the drive orĀ PVR recordings.Ā Any suggestions appreciated. Quote
Ed B Posted March 20, 2021 Author Posted March 20, 2021 31 minutes ago, nbs. said: Formatted? Yeah, there's a known bug that's being worked on...I tried every which way to use added storage and no dice. Formatted on box, pre-formatted, internal, external...nothing is writable. Quote
nbs. Posted March 20, 2021 Posted March 20, 2021 (edited) i know many users with drives working Edited March 20, 2021 by nbs. Quote
whacked Posted March 21, 2021 Posted March 21, 2021 A couple days ago, I had recordedĀ onto a 160GB Toshiba HardDrive (SATA) Seemed to work fine with the recording found on the HDDĀ Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Android>media>buzz.services.pvr But I just tried again and the in 'New Schedule' setup,, I can not choose a dive to record to. The slot to select a drive is stuck in Locating mode. This did work the other day and I had two external drives connected at that time to which both showed in this slot. I have reboot the 4900 a few times but always same result. So I opened a File Manager and I can see the USB drive and the SATA drive and also a Mouse is connected with a USB card and that works fine, so the box is seeing these drives, but seems they are not seen by the recording function. I opened that recording from the other day and it played fine. The Mouse works fine and the Manager sees all the drives.Ā But no drives are seen in the Recording Scheduler setup. Ā I had installed a Buzz5 Beta file since I did that recording, is the only difference. Ā Quote
Ed B Posted March 21, 2021 Author Posted March 21, 2021 54 minutes ago, nbs. said: i know many users with drives working I wish I was one of them, LOL. Quote
Ed B Posted March 21, 2021 Author Posted March 21, 2021 7 minutes ago, Ed B said: I wish I was one of them, LOL. 1 hour ago, nbs. said: i know many users with drives working No matter what drive I connect (USB or SATA) it's showing no write access in FX File Manager. There's an option in FX to SETUP write access, but the next screen says "direct volume access was denied" If I click on the next arrow I receive the following popup System error: "This device does not appear to support the Android Storage Access Framework.Ā (Error: ACTION_OPEN_DOCUMENT_TREE not implemented by device.) Quote
allaboutbuzz Posted March 22, 2021 Posted March 22, 2021 On 3/20/2021 at 8:35 PM, whacked said: A couple days ago, I had recordedĀ onto a 160GB Toshiba HardDrive (SATA) Seemed to work fine with the recording found on the HDDĀ Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Android>media>buzz.services.pvr But I just tried again and the in 'New Schedule' setup,, I can not choose a dive to record to. The slot to select a drive is stuck in Locating mode. This did work the other day and I had two external drives connected at that time to which both showed in this slot. I have reboot the 4900 a few times but always same result. So I opened a File Manager and I can see the USB drive and the SATA drive and also a Mouse is connected with a USB card and that works fine, so the box is seeing these drives, but seems they are not seen by the recording function. I opened that recording from the other day and it played fine. The Mouse works fine and the Manager sees all the drives.Ā But no drives are seen in the Recording Scheduler setup. Ā I had installed a Buzz5 Beta file since I did that recording, is the only difference. Ā PM me Quote
allaboutbuzz Posted March 22, 2021 Posted March 22, 2021 On 3/20/2021 at 8:44 PM, Ed B said: No matter what drive I connect (USB or SATA) it's showing no write access in FX File Manager. There's an option in FX to SETUP write access, but the next screen says "direct volume access was denied" If I click on the next arrow I receive the following popup System error: "This device does not appear to support the Android Storage Access Framework.Ā (Error: ACTION_OPEN_DOCUMENT_TREE not implemented by device.) Yes were fully aware of this issue. 2 Quote
rssgmatt Posted March 23, 2021 Posted March 23, 2021 If anybody gets a fix on this let me know because I am able to see them but unable to record to them. seems I bought a $200.00 paperweight. Quote
nbs. Posted March 23, 2021 Posted March 23, 2021 (edited) 1 hour ago, rssgmatt said: If anybody gets a fix on this let me know because I am able to see them but unable to record to them. seems I boughtĀ Ā Edited March 23, 2021 by nbs. Quote
allaboutbuzz Posted March 23, 2021 Posted March 23, 2021 3 hours ago, rssgmatt said: If anybody gets a fix on this let me know because I am able to see them but unable to record to them. seems I bought a $200.00 paperweight. PM me Thanks Quote
whacked Posted March 23, 2021 Posted March 23, 2021 (edited) I apologize for interupting this thread, but I wanted to report my current standing with the issue I had of not recognizing my external or internal drives in the recording menu (which I reported in this thread a day or two ago). The issue is fixed and now working as designed. Recording onto HDD drives also works fine,Ā SATA type drives included. thnx allaboutbuzz BTW, do you get any sleep ?Ā ... You are a amazing :) Ā Edited March 23, 2021 by whacked 2 Quote
Ogrish58 Posted June 28, 2022 Posted June 28, 2022 Was this issue resolved and if so is there somewhere the solution can be accessed? I bought my box last week and just tried to install a Seagate 500gb from a laptop but had no luck. Quote
dishuser Posted June 28, 2022 Posted June 28, 2022 4 hours ago, Ogrish58 said: Was this issue resolved and if so is there somewhere the solution can be accessed? I bought my box last week and just tried to install a Seagate 500gb from a laptop but had no luck. did you format it as removable(external)? 1 Quote
william agins Posted July 6, 2022 Posted July 6, 2022 How do you play back what you Just recorded from IPTV with XRS4900 Quote
nbs. Posted July 6, 2022 Posted July 6, 2022 (edited) Menu, pvr Also pvr on remote Edited July 6, 2022 by nbs. Quote
M M Posted April 21, 2023 Posted April 21, 2023 Hi, Ā how can I do a simple copy and paste of a file to a external USB device. It is always mounted read only. I just want to copy and paste and I can't do this. Ā Regards Martin Quote
