laflores15 Posted March 8, 2021 Posted March 8, 2021 Hi, my xrs4500 when pushing the power key button on the remote it will not suspend like it was before this is with the remote that came with the device as well as the one I purchased here the ARQ-100. I have tried rebooting changing the power key definition to shut down it does that, and it will restart with both remotes, I have unplugged it for a few minutes it has the same Issue not suspending. Quote
nbs. Posted March 8, 2021 Posted March 8, 2021 What are the options when you hold power button down? Quote
laflores15 Posted March 8, 2021 Author Posted March 8, 2021 Power-off, restart, screenshot. it's working now that I unplugged it for about an hour, thanks for the reply. Quote
nbs. Posted March 8, 2021 Posted March 8, 2021 What are the options if you change power key to suspend? Quote
spudnuts Posted March 10, 2021 Posted March 10, 2021 Yeah, mine does that every now and again. Seems to be worse when the batteries are in the way out. Remote eats batteries. Quote
