Polaybuzz Posted March 23, 2023 Share Posted March 23, 2023 I just got a new Classic box but for some reasons the catch up do not work. I get "Media format is not supported" message at the bottom of the TV screen. What settings do I need to change please? Quote Link to comment Share on other sites More sharing options...
nbs. Posted March 23, 2023 Share Posted March 23, 2023 You on Primary player? Quote Link to comment Share on other sites More sharing options...
Polaybuzz Posted March 23, 2023 Author Share Posted March 23, 2023 (edited) Yes! I have tried with "Backup" player in Live TV video player settings and it doesn't work. Edited March 23, 2023 by Polaybuzz Quote Link to comment Share on other sites More sharing options...
nbs. Posted March 23, 2023 Share Posted March 23, 2023 Buzz fixed the issue on your server with the android 9 units Should be fixed soon with the android 11 units 2 Quote Link to comment Share on other sites More sharing options...
Polaybuzz Posted April 4, 2023 Author Share Posted April 4, 2023 Thanks, great update, the catch up are working! However I am forced to use HLS protocol to be able to view catch up with my provider. Is it normal? Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted April 4, 2023 Share Posted April 4, 2023 3 minutes ago, Polaybuzz said: Thanks, great update, the catch up are working! However I am forced to use HLS protocol to be able to view catch up with my provider. Is it normal? Good to hear. There are 2 stream types usually TS and HLS Some work better than others, it varies So as long as it works, that's all that matters. 3 Quote Link to comment Share on other sites More sharing options...
