X5 Buzz volume keeps dropping off.
Dynas
25 minutes ago, Dynas said:
The box volume has not worked since the last update
Have you checked in the settings if the "Max volume" option is enabled ?   If MAX Volume is enabled, then you only control volume from your TV (so volume on box does nothing).   If Max volume is turned off, then the box has variable volume controlled by the volume buttons.
