Programs won't stop blinking
Geetek1
Have you tried another HDMI cable ?
Are you using the oiginal power adapter that came with the U5 ?  Reason I ask, is because many people are in a rush to test out their new toy, and assume it uses the same power supply as previous boxes.  But the U5 and the xrs4900 use a 12V power supply.  All other boxes, it is 5V.  So if you use the power supply from another buzz box, the box will not have enough power 🙂  Just checking.  Seen it happen many times.
Hi,
I have a xrs4500 that is doinoku T g this "blinking" thing.  Meaning the picture would go blank then come back on.  Now, the tv will not recognize the buzz box.  It"s asking if it's turned on.  The TV is TCL Roku TV.  I'm using the original power cord and bought a new certified HDMI cable.
5 minutes ago, Ray said:
I pressed it and held for 10 secs or so.  Nothing seems to be happening.  What is the proper procedure?  Should I see the blue light turn off and on?
If you click the link provided by dishuser, it has a video with step by step details.
https://stbtalk.com/index.php?/topic/300-factory-reset-hard-reset-xr4500-xrs4500/
unplug the box
press and hold the button and then plug it in
after about 10-15 seconds you'll get the recovery screen
