Jappy Posted February 7, 2021 Share Posted February 7, 2021 For the last month, time shift function does not work anymore on my XRS 4000. When I select an available show on a channel that indicates time shift available, it lags and lags without displaying any image. I decided to install stub emu pro on my box using the same server and time shift works perfectly... I have the latest release of BuzzTV 4. Before holidays, it usually worked properly. What can I do since I prefer the interface of BuzzTV to stub emu pro? Quote Link to comment Share on other sites More sharing options...
dishuser Posted February 7, 2021 Share Posted February 7, 2021 try clearing cache Quote Link to comment Share on other sites More sharing options...
dishuser Posted February 7, 2021 Share Posted February 7, 2021 or change player Quote Link to comment Share on other sites More sharing options...
Jappy Posted February 7, 2021 Author Share Posted February 7, 2021 I made 3 factory reset s and it did not anything. I am using the default player: secondary,,, Where can I empty the cache? In advanced settings? Under applications ? Quote Link to comment Share on other sites More sharing options...
dishuser Posted February 7, 2021 Share Posted February 7, 2021 settings/apps/buzztv 4 Quote Link to comment Share on other sites More sharing options...
Jappy Posted February 7, 2021 Author Share Posted February 7, 2021 Ok, I found out for cache, No change after I emptied it. I changed the player as well to default,. Same thing; no change. Time shift still not working with ByzzTV 4 but perfect with stub emu pro. Quote Link to comment Share on other sites More sharing options...
dishuser Posted February 7, 2021 Share Posted February 7, 2021 1 hour ago, JP Tremblay said: Ok, I found out for cache, No change after I emptied it. I changed the player as well to default,. Same thing; no change. Time shift still not working with ByzzTV 4 but perfect with stub emu pro. time shift worx for me using buzztv 4 Quote Link to comment Share on other sites More sharing options...
dishuser Posted February 7, 2021 Share Posted February 7, 2021 and just checked and I'm using secondary player Quote Link to comment Share on other sites More sharing options...
nbs. Posted February 8, 2021 Share Posted February 8, 2021 4 hours ago, JP Tremblay said: Ok, I found out for cache, No change after I emptied it. I changed the player as well to default,. Same thing; no change. Time shift still not working with ByzzTV 4 but perfect with stub emu pro. you need to pm alboutbuzz with your info to figure out the issue Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted February 8, 2021 Share Posted February 8, 2021 16 hours ago, nbs. said: you need to pm alboutbuzz with your info to figure out the issue Yes please do this Quote Link to comment Share on other sites More sharing options...
