EPG Not populating BuzzTV XR 4000 Firmware Version: V20201219
TheGhost
2 minutes ago, TheGhost said:
That person should not even be reporting his issues here he has hijacked my thread
he should have created his own thread!  are you a mod here? if not then please
 be quiet.
stop being a dick and ill be quiet
On 3/13/2021 at 12:38 PM, TheGhost said:
No it isn't fixed that is why i am reporting it. The issue isn't fixed
also the issue which is why I am reporting it here.
Also the issue with the Blue tooth has stopped responding
is also not fixed which they claim they fixed in the last patch
as well.   Neither issue is resolved.
We had to get a few users local to us to lend us their 4000s with this issue.
As this issue has been difficult so far to fix, as its only happening to a small amount of users
Were going to spend next week debugging this and then try to fix it.
  • Thanks 1
  • 4 weeks later...
I also sometimes have slow loading issues with a buzz xrs4500 epg when i used xc API to log in. But if i use m3u with a link for epg, it loads quickly but then the series doesn't load so i am forced to return to Xc API. The epg issue is as mentioned above.  The channel i am watching will load the epg information but then all the other channels on the page take quite a long time to display any information
you should be posting in the 4500 forum
PM me about both issues
Thanks
