I believe what you are seeing is like a 'trailer' for the Series. Sometimes with that same screen you will get a Play button for the trailer as well, and then you can view the trailer, but not the Series itself.
I have experienced this when using an m3u Playlist connection method (and maybe API connection too, but do not recall for sure), but I saw this with some VODS or Series. Switching to MAC connection, then all is normal again and plays.
So it looks like your server may not have the actual links to the Series episodes and has only the trailer link, maybe --> ??
Or try the switch to MAC or vice versa to API to see if any differences.
Edited by whacked
