Kroach2159 Posted December 10, 2020 Share Posted December 10, 2020 I purchased the WD My Passport external drive for my XRS4500 box. I could not get it set up correctly. Could someone share how to install the external drive ? I called WD they said it only works on windows and Mac's. if that is the case can you recommend a external drive for it ? Thanks in advance Quote Link to comment Share on other sites More sharing options...
nbs. Posted December 10, 2020 Share Posted December 10, 2020 I know of guys using 1T hdd but I dont know the brand I use a 256 gig micro sd myself Sorry i cant help you with the hard drive Quote Link to comment Share on other sites More sharing options...
Kroach2159 Posted December 10, 2020 Author Share Posted December 10, 2020 Thanks nbs Quote Link to comment Share on other sites More sharing options...
whacked Posted December 10, 2020 Share Posted December 10, 2020 been using WD My Passport 1TB HDD pretty much on all devices, from Windows to android boxes. With these Buzz boxes and that large amount of HDD you are connecting to them, you need to safely add or remove the drive to and from USB port. That means power off the Buzz box and then connect the drive to it and power back on. You can connect to a powered on Buzz box, but you would have to watch your Buzz go thru a reboot. I can tell you with experienced testing that when I connect my WD MyPassport 1TB to the powered up XRS4500 or XR4000, the buzz box goes thru a reboot sequence. It does work after the cycle completes and can see and access the drive's content fine. If you have issues with that drive, maybe you need to enter it's Properties thru your windows Control Panel and delete it and then re-install. That might give that WD a kick in the pants and then your buzz may see it Them guys at WD support seem not to know things, lol.... unless something changed with their new models, I been using WD products forever, with no issues on androids. Quote Link to comment Share on other sites More sharing options...
Kroach2159 Posted December 10, 2020 Author Share Posted December 10, 2020 When I plug it in that is it, I don't have to add it to the Buzz box? When I first hooked it up it did ask me did I want to format to this device, the buzztv. Now the only place I even see it is inS Explorer as a OTG1,. When I attempt to add anything I Geta cannot connect this needs to be a NF1 or Fat (something like that ). Are you saying I should hook theWD to my MacBook and and delete it? What is it? LOL. Thanks, I appreciate your help. I thought I read somewhere that 1TB was the max? Quote Link to comment Share on other sites More sharing options...
whacked Posted December 10, 2020 Share Posted December 10, 2020 Okay,forget about the deleting thing, that was just to reestablish the driver on your PC and therefore may have been seen by the buzz... BUT Sound like it just needs to be formated. Format to FAT or xFAT You can do that with it connected to your PC... I do not have experience with MAC Books thou. Quote Link to comment Share on other sites More sharing options...
whacked Posted December 11, 2020 Share Posted December 11, 2020 with a google search I found some info... The way you reformat a volume on a Mac is using Disk Utility In general any FAT format should work on both a PC and a Mac as I understand it (not from personal experience but from others). If you need more info on the process, a simple google search should help. And also if you have any content on that drive, you should transfer it onto PC or MAC before formatting. The formatting process with preeminently delete all content from the drive. And on another note, I found that formatting a large drive like a 1 TB works better thru a formatting tool such as Swissknife, as apposed to the windows PC format tool. MAC may be different and may be just fine without the need for additional tool. Quote Link to comment Share on other sites More sharing options...
dishuser Posted December 11, 2020 Share Posted December 11, 2020 why not just format it with the buzz? Quote Link to comment Share on other sites More sharing options...
whacked Posted December 11, 2020 Share Posted December 11, 2020 4 minutes ago, dishuser said: why not just format it with the buzz? I did not know the buzz had that ability. That certainly would be the easiest, as long as the size of the drive is not a factor. cool Quote Link to comment Share on other sites More sharing options...
dishuser Posted December 11, 2020 Share Posted December 11, 2020 all models can Quote Link to comment Share on other sites More sharing options...
nbs. Posted December 11, 2020 Share Posted December 11, 2020 4 minutes ago, whacked said: I did not know the buzz had that ability. That certainly would be the easiest, as long as the size of the drive is not a factor. cool Yeppirs Quote Link to comment Share on other sites More sharing options...
Kroach2159 Posted December 11, 2020 Author Share Posted December 11, 2020 When you format it with the Buzz it will only work on the Buzz correct.? NBS, man you have been great, I see why you hav so many thank you 's. Quote Link to comment Share on other sites More sharing options...
