Resolution check?
alikair
On 9/7/2020 at 11:19 AM, nbs. said:
not at this time Its been considered in a future update
This is correct
We plan to add this to the Info screen
So basically if you press the info button 2 times, where it has Show Description
We will add Resoltion + Codec information listed here
It is a very similar feature to what You Tube has with "Stats for Nerds"
