alikair Posted August 2, 2020 Share Posted August 2, 2020 Is there a way to program the powers button to turn off the TV and the receiver at the same time like my fire stick Quote Link to comment Share on other sites More sharing options...
nbs. Posted August 2, 2020 Share Posted August 2, 2020 Which remote? Quote Link to comment Share on other sites More sharing options...
nbs. Posted August 2, 2020 Share Posted August 2, 2020 There are instructions in the manual Quote Link to comment Share on other sites More sharing options...
mopar.man Posted August 27, 2020 Share Posted August 27, 2020 where do i find the manual for the 4500 keyboard type remote? Thanks james Quote Link to comment Share on other sites More sharing options...
dishuser Posted August 28, 2020 Share Posted August 28, 2020 3 hours ago, mopar.man said: where do i find the manual for the 4500 keyboard type remote? Thanks james I'm guessing you mean the arq-100?? 1 Quote Link to comment Share on other sites More sharing options...
mopar.man Posted August 30, 2020 Share Posted August 30, 2020 Hi thanks just got this thanks , gave it a try so far still not quite getting it to work. flashes and such but wont seem to take the remote signal will keep trying. Thanks for the info. Quote Link to comment Share on other sites More sharing options...
Nelutz Posted September 2, 2020 Share Posted September 2, 2020 On 8/29/2020 at 8:30 PM, mopar.man said: Hi thanks just got this thanks , gave it a try so far still not quite getting it to work. flashes and such but wont seem to take the remote signal will keep trying. Thanks for the info. Try it more ,I had some problems till I got it work ,all and all the remote is awesome Quote Link to comment Share on other sites More sharing options...
mopar.man Posted September 8, 2020 Share Posted September 8, 2020 thanks finally got it was not using original remote was using cable company remote. Works great .. Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted September 9, 2020 Share Posted September 9, 2020 On 9/7/2020 at 10:39 PM, mopar.man said: thanks finally got it was not using original remote was using cable company remote. Works great .. Good to hear that. Quote Link to comment Share on other sites More sharing options...
