Torontorocko Posted July 7, 2020 Posted July 7, 2020 Any word on the shutdown issue? getting a fix for it? Quote
nbs. Posted July 7, 2020 Posted July 7, 2020 allaboutbuzz has not posted anything I am sure its being worked on Quote
allaboutbuzz Posted July 7, 2020 Posted July 7, 2020 14 hours ago, Torontorocko said: Any word on the shutdown issue? getting a fix for it? Should be fixed this month. Its an odd issue that needs time to address I'll update here once I know more 2 Quote
allaboutbuzz Posted August 25, 2020 Posted August 25, 2020 21 hours ago, Pete970 said: Any word on the fix This is a weird one It seems that if there are nearby Bluetooth devices, that is whats causing the box to reboot/wakeup when shutdown. After numerous tests and logs, this is what has been determined as the root cause Now we will be working on fixing it. 1 Quote
Kerruptor Posted September 15, 2020 Posted September 15, 2020 Is there any update on when this will be fixed. Having to unplug the XRS4000 after every use is really a pain. It worked fine before the June update. Would be nice to see it fixed .... just saying. Quote
nbs. Posted September 15, 2020 Posted September 15, 2020 (edited) Are you sure you cant shutdown by setting in to standby and just hitting power button once quickly? Edited September 15, 2020 by nbs. 1 Quote
allaboutbuzz Posted September 15, 2020 Posted September 15, 2020 7 hours ago, Kerruptor said: Is there any update on when this will be fixed. Having to unplug the XRS4000 after every use is really a pain. It worked fine before the June update. Would be nice to see it fixed .... just saying. We have been testing a solution for a week now Once it passes internal testing, we will release it to Beta So far it hasn't failed internal testing. 1 Quote
Kerruptor Posted September 15, 2020 Posted September 15, 2020 1 minute ago, allaboutbuzz said: We have been testing a solution for a week now Once it passes internal testing, we will release it to Beta So far it hasn't failed internal testing. Thanks for the update. Happy to hear it's being addressed. 1 Quote
Kerruptor Posted October 13, 2020 Posted October 13, 2020 On 9/15/2020 at 2:32 PM, allaboutbuzz said: We have been testing a solution for a week now Once it passes internal testing, we will release it to Beta So far it hasn't failed internal testing. Is this going to be fixed anytime soon? So frustrating to have to keep unplugging the box since the June update. How do you get the beta version? I'd be willing to try it. Quote
nbs. Posted October 13, 2020 Posted October 13, 2020 you'll just have to be patient It'll be fixed with the new file Quote
Kerruptor Posted November 11, 2020 Posted November 11, 2020 On 10/13/2020 at 11:59 AM, nbs. said: you'll just have to be patient It'll be fixed with the new file How long to we have to be patient? I would think Buzz would want to repair this before people start considering alternative boxes. I was pleased with my first Buzz box XPL3000 so I bought the XRS4000 but I think I'd have to reconsider getting any other Buzz products due to this issue. We've been told the fix will be released long ago and 5 months have transpired since the last update. I hate complaining but this is a real annoyance. 1 Quote
