DAZN app does not work
cocog
I have installed DAZN app on my XRS4000 and it does not work.
I can log in, I can see all the streams (tiles) but when I select one I get an error saying to check my Internet connection or my number of devices using the account, code 11-003-013.
The Internet connection is great, there was only one device in use on my DAZN account.
I called DAZN and they took the easy way out: this box is not on the "official" list of supported devices. 😒
Other streaming services work nicely with XRS4000.
All my other devices (TVs, phones, PCs) are working with DAZN.
I had on older BuzzTV model that did work with DAZN app. I also tried older versions of the DAZN app from (Aptoide TV) and still no go.
There is some incompatibility between this model and DAZN stream. Can the developers look into this? This may be something very minor and it would be a shame to not fix it such a nice piece of hardware.
Thank you !
Thank you !
Thanks for posting this
Will pass this to the developers to see whats wrong
Will just need to get an account and run log test to see whats going on.
That would be great !  DAZN showed not much interest at their end.
Thank you !
Thank you !
When it comes to Android, there are just way too many devices to support for apps like DAZN
So that is a pretty typical response from companies like DAZN.
Will look into this and update you here.
20 hours ago, danny121pt said:
While the dev look into dazn app, you could use dazn via kodi official repo until dev look into it.
its not the best. but may help you for
time being.
yes, that's what I am doing now, thank you
What threw me off was that the old BuzzTV box I had (I think it was an XPL3000 but I am not 100%) did work.
it's not the end of the world 🙂 but it would be nice to get it working again.
Thank you again !
  • 2 weeks later...
time being.
DAZN via Kodi stopped working recently 😞
  • 2 weeks later...
  • 1 month later...
Hi,
any updates on this?
thank you!
  • 7 months later...
I just bought the XRS4500Max and installed DAZN thru two different sources, Google Play and a 1.6x version APK. In both cases on the 4500 I can log in, but then an error is thrown.
The GooglePlay version installs on my Samsung tablet fine and runs
it is an important app for me... I will try to install DAZN on the Kodi 18.9 as an alternate method
thx in advance
