rdw33 Posted November 12, 2022 Author Share Posted November 12, 2022 XRS4500 3 Quote Link to comment Share on other sites More sharing options...
Dave J Posted November 12, 2022 Share Posted November 12, 2022 I was enquiring about a replacement BT-100 for my XRS 4500 MAX, and was informed by cs@buzztv that the BT-100 / 200 are discontinued. The new XRS 4500's are being shipped with the BT-300 (BT-400 I think is the same unit). The new boxes don't have the smart remote app as they are Android 9, and the app is for Android 11. As I understand it Buzz is working on an update that will turn the back light on and off, and allow the colour button mapping. However, you can program the BT-400 manually as outlined in the instruction manual. Hope that helps. Quote Link to comment Share on other sites More sharing options...
rdw33 Posted November 12, 2022 Author Share Posted November 12, 2022 Looking forward to the update!! Quote Link to comment Share on other sites More sharing options...
nbs. Posted November 13, 2022 Share Posted November 13, 2022 1 hour ago, Dave J said: I was enquiring about a replacement BT-100 for my XRS 4500 MAX, and was informed by cs@buzztv that the BT-100 / 200 are discontinued. The new XRS 4500's are being shipped with the BT-300 (BT-400 I think is the same unit). The new boxes don't have the smart remote app as they are Android 9, and the app is for Android 11. As I understand it Buzz is working on an update that will turn the back light on and off, and allow the colour button mapping. However, you can program the BT-400 manually as outlined in the instruction manual. Hope that helps. I don't believe that the app is android 11. Last I heard they were going to be adding it to the android 9 units 3 Quote Link to comment Share on other sites More sharing options...
rdw33 Posted November 13, 2022 Author Share Posted November 13, 2022 Bring it! Quote Link to comment Share on other sites More sharing options...
Pauly Posted November 13, 2022 Share Posted November 13, 2022 yeah bring it to the other boxes pls Quote Link to comment Share on other sites More sharing options...
