spamham Posted June 15, 2020 Posted June 15, 2020 Today, there is a way for us to schedule a recoding for a given time. How to make this a recurring task where we can choose days and time? Can someone help? Quote
whacked Posted June 15, 2020 Posted June 15, 2020 while LiveTV is playing, press the red button at bottom left on your RCU Is that what you are looking for ? Quote
spamham Posted June 16, 2020 Author Posted June 16, 2020 1 hour ago, whacked said: while LiveTV is playing, press the red button at bottom left on your RCU Is that what you are looking for ? 1 hour ago, dishuser said: menu while in live tv and then pvr This process outlined by you will enable recording for one item only. There is no mechanism that i have discovered that allows setting up recurring DVR entry. Quote
nbs. Posted June 16, 2020 Posted June 16, 2020 3 hours ago, spamham said: Today, there is a way for us to schedule a recoding for a given time. How to make this a recurring task where we can choose days and time? Can someone help? maybe in a future update Quote
dishuser Posted June 16, 2020 Posted June 16, 2020 you can manually setup recordings you can't set it to repeat weekly but you can manually do that Quote
JohnLWay Posted May 4, 2021 Posted May 4, 2021 Anybody hear anymore on when we might be able to have recurring recordings like a typical DVR recorder. Doesn't make any sense that we can't record every day at the same time or once a week at the same time? I'm getting ready to return my Buzz box since it doesn't have these basic record functions. Quote
allaboutbuzz Posted May 4, 2021 Posted May 4, 2021 14 hours ago, JohnLWay said: Anybody hear anymore on when we might be able to have recurring recordings like a typical DVR recorder. Doesn't make any sense that we can't record every day at the same time or once a week at the same time? I'm getting ready to return my Buzz box since it doesn't have these basic record functions. Being worked on right now for Buzz 5 To be released on the 4900 first. Will be available for Beta soon though on 4500s and 4000s. 3 Quote
Mulder99 Posted January 15, 2024 Posted January 15, 2024 any update on recurring recording yet for the 4500? 1 Quote
Emporium Posted January 15, 2024 Posted January 15, 2024 You revive a 2.5yr old thread, for an update on something that has existed for ages ? Just go into your PVR option, scheduled recording, and on top you can select one time recording, or multi-day... MultiDay you can select only specific days if you want (like Mon, Wed, Friday, or every day if you please, or even just one day (like Monday only) and it will repeat continuously until you stop it. 2 Quote
dishuser Posted January 15, 2024 Posted January 15, 2024 2 hours ago, Mulder99 said: any update on recurring recording yet for the 4500? https://stbtalk.com/topic/4329-new-buzz-5-app-update-for-beta-users-version-50766-sept-14th-2022/ 1 Quote
