Emporium Posted October 23, 2022 Posted October 23, 2022 Both BT and IR don't work ? If you "point" the remote to the box, it still does not work ? Have you tried unplugging the box, and then re-plugging it back in to force a clean boot ? Sometimes the Bluetooth will do strange things after a major firmware update. What I do in those cases, is simply go into the settings for Remote and accessories, unpair the remote, and then re-pair it again. Takes a whole 2 minutes max. 1 Quote
sea157 Posted October 23, 2022 Posted October 23, 2022 Did you try new batteries in your remote? These remotes go through batteries very fast! Quote
dishuser Posted October 23, 2022 Posted October 23, 2022 27 minutes ago, sea157 said: Did you try new batteries in your remote? These remotes go through batteries very fast! my energizer rechargeable last almost a year per charge I don't use back light cause I know where all the buttons are...lol that's what kills batteries Quote
allaboutbuzz Posted October 23, 2022 Posted October 23, 2022 13 hours ago, DennisL said: Any ideas why and how to fix it? Make sure both Wifi and Bluetooth are turned on in Settings The error should go away afterwards. Quote
DennisL Posted October 24, 2022 Author Posted October 24, 2022 I did all of the above. Tonight, when I powered on the XRS4900, it kept saying that Bluetooth has stopped working. I shut it down, unplugged it, waited 30 seconds, then plugged it back in. It seems to be working fine now. Fingers crossed that it will continue. Thank you. Quote
allaboutbuzz Posted October 24, 2022 Posted October 24, 2022 12 hours ago, DennisL said: I did all of the above. Tonight, when I powered on the XRS4900, it kept saying that Bluetooth has stopped working. I shut it down, unplugged it, waited 30 seconds, then plugged it back in. It seems to be working fine now. Fingers crossed that it will continue. Thank you. Did you try this? Make sure both Wifi and Bluetooth are turned on in Settings The error should go away afterwards. Quote
