BuzzNutzer Posted September 16, 2022 Posted September 16, 2022 Hello, I have buzztv xrs 4900, UHD Channels not working on Buzztv 5, only HD channels working Watching UHD channels the picture suddenly stops or runs slower What is causing this problem? And how can I solve it? Thanks for your help Quote
Ryu Posted September 16, 2022 Posted September 16, 2022 they are working fine for me on many servers. try to switch player and see if that helps. it might be server related. 1 Quote
BuzzNutzer Posted September 18, 2022 Author Posted September 18, 2022 I have in configuration settings only secondary or default, with secondary working UHD Channels, but audio of HD channels not working Quote
nbs. Posted September 18, 2022 Posted September 18, 2022 1 hour ago, BuzzNutzer said: I have in configuration settings only secondary or default, with secondary working UHD Channels, but audio of HD channels not What do the audio settings say ? Disabled? 1 Quote
nbs. Posted September 18, 2022 Posted September 18, 2022 It shows you have another option to change it to 1 Quote
BuzzNutzer Posted September 18, 2022 Author Posted September 18, 2022 when I choose the other option come "stream error" Quote
nbs. Posted September 18, 2022 Posted September 18, 2022 Send allaboutbuzz a pm with all your info and the issue you are having and he can look at it further Quote
