Peter Smetana Posted August 17, 2022 Share Posted August 17, 2022 I noticed that when I record a program on the XRS4500 box, the audio and video are not synchronized. Video is behind. Is there any way to fix this? I should point out that my software is up to date. Peter Quote Link to comment Share on other sites More sharing options...
nbs. Posted August 17, 2022 Share Posted August 17, 2022 Have you tried both players? 1 Quote Link to comment Share on other sites More sharing options...
Emporium Posted August 18, 2022 Share Posted August 18, 2022 When you say you software is up to date, is it latest beta, or latest public release ? From Menu, on the bottom, what version of software are you running ? Also, as nbs has posted in order threads, this might help for users running buzz 5 and android 9 https://www.mediafire.com/file/epmf5i0suejl6rj/com_buzz.services.pvr_33_5056428e-2cad-4bbe-9a31-4e13bdb55857.apk/file I typically record on my 4900, and haven't done much recording on my 4500, but when I had tried it in the past it was perfectly fine. Are you recording to an external USB drive ? If you are, just for a test, can you change the destination to the internal storage and try a small recording to that ? Quote Link to comment Share on other sites More sharing options...
