Tony Downey Posted April 14, 2020 Share Posted April 14, 2020 Has anyone been able to get any USB debugging working on this device? Link to comment Share on other sites More sharing options...
allaboutbuzz Posted April 14, 2020 Share Posted April 14, 2020 1 hour ago, Tony Downey said: Has anyone been able to get any USB debugging working on this device? Not really What did you need to use it for? Link to comment Share on other sites More sharing options...
Tony Downey Posted April 15, 2020 Author Share Posted April 15, 2020 I'm a developer, trying to make software for boxes like this. I'm trying to run some Android Developer Bridge commands on the XR4000 - but unlike other boxes I've used, when I put it in developer mode, none of the USB ports change over to debugging ports. Link to comment Share on other sites More sharing options...
allaboutbuzz Posted April 15, 2020 Share Posted April 15, 2020 1 hour ago, Tony Downey said: I'm a developer, trying to make software for boxes like this. I'm trying to run some Android Developer Bridge commands on the XR4000 - but unlike other boxes I've used, when I put it in developer mode, none of the USB ports change over to debugging ports. Its because we turned it off on our boxes.Β Link to comment Share on other sites More sharing options...
Tony Downey Posted April 15, 2020 Author Share Posted April 15, 2020 Is there any way to turn it back on, or another model that has a USB debugging port? I work for a digital signage company, we're trying to find an Android box for our needs. We need a model that's cheap and plentiful, since we're buying about 500 per year right now. But if we can't run ADB commands that's a deal breaker. Link to comment Share on other sites More sharing options...
allaboutbuzz Posted April 15, 2020 Share Posted April 15, 2020 21 minutes ago, Tony Downey said: Is there any way to turn it back on, or another model that has a USB debugging port? I work for a digital signage company, we're trying to find an Android box for our needs. We need a model that's cheap and plentiful, since we're buying about 500 per year right now. But if we can't run ADB commands that's a deal breaker. PM me pleaseΒ Link to comment Share on other sites More sharing options...
Nelutz Posted April 15, 2020 Share Posted April 15, 2020 54 minutes ago, Tony Downey said: Is there any way to turn it back on, or another model that has a USB debugging port? I work for a digital signage company, we're trying to find an Android box for our needs. We need a model that's cheap and plentiful, since we're buying about 500 per year right now. But if we can't run ADB commands that's a deal breaker. Cheap and plentiful?? What do want to buy potatoes? ,I don't think Buzztv have cheap and plentiful boxes ,or do they? Link to comment Share on other sites More sharing options...
nbs. Posted April 15, 2020 Share Posted April 15, 2020 Prices do go down significantly when buying in bulk Allaboutbuzz can deal with it 1 Link to comment Share on other sites More sharing options...
allaboutbuzz Posted April 15, 2020 Share Posted April 15, 2020 I have locked this Thread As it is being taken care of via PM 1 Link to comment Share on other sites More sharing options...
