XPL 3000 Slow Box Issue
glingan
Hi,
When I plug in my box and begin to watch a live TV, there is no issue with the quality and stream speed.
However, after about an hour or so, sometimes shorter - the live tv slows down and i need to unplug and plug in the power, and then the picture returns to normal.
If I leave my box on for a couple of days, the picture is frozen when i get back to it and i need to reboot the box as above.
Can anyone advise on what the issue is? And how to resolve this?
Thanks
Lingan
4 hours ago, glingan said:
Hi,
Thanks
Lingan
can you check your disk space first, by going to apps then file manager make sure your space has atleast 15% empty space.
if  not then please reply we could give you some other steps to empty space.
On 1/29/2020 at 10:21 AM, nbs. said:
why would you leave your box o for a couple of days?
there should also be no need to unplug ,Hold power button down and select reboot
Some providers have a built in feature that stops streams if a box is left on for like 3-6 hours
This is a built in feature into their backend to help save them bandwidth
A simple channel change will reactivate the stream when this happens.
Im aware ,was just wondering why they would leave box on
