Maddogg Posted February 10, 2022 Posted February 10, 2022 My mouse does not work…just creeps along not float as it should. Why? Tried update and type in 2012 as well. Bluetooth is on and I have to use it because the stick is in the back of the tv. Please help anyone. Quote
nbs. Posted February 10, 2022 Posted February 10, 2022 its 2015 not 2012 Doesnt matter if your stick is behind tv Plug in your ir extender so your remote can see it Quote
dishuser Posted February 10, 2022 Posted February 10, 2022 2 hours ago, Maddogg said: My mouse does not work…just creeps along not float as it should. Why? Tried update and type in 2012 as well. Bluetooth is on and I have to use it because the stick is in the back of the tv. Please help anyone. you can change mouse speed settings/device preferences/keyboard & autofill Quote
Maddogg Posted February 10, 2022 Author Posted February 10, 2022 Thank you for mouse up date. I set the mouse to max speed. Works great. I had hoped for a floating mouse like my Mygica but this will do. How do I get Buzztv 5 beta update? I saw the download but how do I get it on my Buzztv stick max? Thanks. Quote
nbs. Posted February 10, 2022 Posted February 10, 2022 The thread explains in detail how to do it 1 Quote
dishuser Posted February 10, 2022 Posted February 10, 2022 30 minutes ago, Maddogg said: Thank you for mouse up date. I set the mouse to max speed. Works great. I had hoped for a floating mouse like my Mygica but this will do. How do I get Buzztv 5 beta update? I saw the download but how do I get it on my Buzztv stick max? Thanks. if you want a floating mouse get the arq-100 remote 2 Quote
Maddogg Posted February 10, 2022 Author Posted February 10, 2022 Thanks. I will try the ARQ 100 remote. Quote
Sevonne Robinson Posted February 11, 2022 Posted February 11, 2022 A few days ago my buzz tv vidstick automatically updated and now it doesn't even turn on. Nothing comes up the screen is just blank. Quote
Sevonne Robinson Posted February 11, 2022 Posted February 11, 2022 2 hours ago, Ryu said: have you tried reset with toothpick? Yes I did nothing works Quote
nbs. Posted February 11, 2022 Posted February 11, 2022 (edited) Email buzz Cs at buzztv.com Edited February 11, 2022 by nbs. Quote
dishuser Posted February 11, 2022 Posted February 11, 2022 15 minutes ago, Sevonne Robinson said: Yes I did nothing works you held button down and then applied power while still holding button down? 1 Quote
Ryu Posted February 11, 2022 Posted February 11, 2022 5 hours ago, Sevonne Robinson said: A few days ago my buzz tv vidstick automatically updated and now it doesn't even turn on. Nothing comes up the screen is just blank. try to reseat hdmi cable or take out stick from tv and reinsert or try different hdmi port and see if thet helps. Quote
Sevonne Robinson Posted February 12, 2022 Posted February 12, 2022 (edited) 7 hours ago, Ryu said: I switched around the hdmi and I tried the other ports it just says no signal Edited February 12, 2022 by Sevonne Robinson Made mistake when typing Quote
Ryu Posted February 12, 2022 Posted February 12, 2022 how are you providing power to your stick? try usb if you are not using or if you are using usb then try direct from wall. Quote
dishuser Posted February 12, 2022 Posted February 12, 2022 1 hour ago, Sevonne Robinson said: I switched around the hdmi and I tried the other ports it just says no signal you never answered about reset Quote
Sevonne Robinson Posted February 12, 2022 Posted February 12, 2022 23 hours ago, Ryu said: have you tried reset with toothpick? I holded the reset button for 10 secs but nothing worked Quote
dishuser Posted February 12, 2022 Posted February 12, 2022 21 minutes ago, Sevonne Robinson said: I holded the reset button for 10 secs but nothing worked post the steps you took Quote
Ryu Posted February 12, 2022 Posted February 12, 2022 do you even feel click when you press? keep holding until you see the recovery screen. Quote
Sevonne Robinson Posted February 13, 2022 Posted February 13, 2022 (edited) Yes I felt the click but it didn't work when I pushed the button. Edited February 13, 2022 by Sevonne Robinson Did finish typing Quote
