Hyper1 Posted January 24, 2022 Posted January 24, 2022 Have a 4500 max just did the beta 5 update. Update seems to be fine so far but playback of YouTube vanced and iptv services are darker than usual. Can this be fixed . Open to suggestions thx Quote
dishuser Posted January 24, 2022 Posted January 24, 2022 17 minutes ago, Hyper1 said: Have a 4500 max just did the beta 5 update. Update seems to be fine so far but playback of YouTube vanced and iptv services are darker than usual. Can this be fixed . Open to suggestions thx you can adjust picture settings Quote
Hyper1 Posted January 24, 2022 Author Posted January 24, 2022 I just thought it was strange becuz I don't have to do it with the other boxes. Quote
allaboutbuzz Posted January 25, 2022 Posted January 25, 2022 20 hours ago, Hyper1 said: I just thought it was strange becuz I don't have to do it with the other boxes. Did the settings change work though? Quote
Hyper1 Posted January 25, 2022 Author Posted January 25, 2022 Settings on box , no, settings on TV, yes. This is aggravating! Quote
nbs. Posted January 25, 2022 Posted January 25, 2022 another person said setting hdr to adaptive helped his video 1 Quote
Hyper1 Posted January 25, 2022 Author Posted January 25, 2022 Thx, that helped quite a bit. Thank you Quote
stevestad Posted February 3, 2022 Posted February 3, 2022 The adaptitive hdr helped me as well. I found that picture settings for Live TV did not work well in many videos. I was changing VOD settings to brighten up, and then having to change them again For Live TV. Just looked at a dark video from last night & it was better Quote
