keng Posted January 12 Posted January 12 The epg guide for live TV is not updating. I have the same stream/server on the iptv"s own app and it updating fine. Help? Quote
Emporium Posted January 12 Posted January 12 from Menu->settings->configuration, scroll down to EPG section, and Clear EPG. This will clear out the current content and force it to re-download it. Also in the same area, you might have the options for EPG type "xml or server". Try toggling it clearing does not help. Quote
dishuser Posted January 12 Posted January 12 28 minutes ago, Emporium said: from Menu->settings->configuration, scroll down to EPG section, and Clear EPG. This will clear out the current content and force it to re-download it. Also in the same area, you might have the options for EPG type "xml or server". Try toggling it clearing does not help. server type is not available when using mac 1 Quote
allaboutbuzz Posted January 13 Posted January 13 20 hours ago, keng said: I'm using xtream codes Press Menu Go to Settings Go to Configuration Change EPG Source from XML to Server 1 Quote
keng Posted January 15 Author Posted January 15 I tried all of the above suggestions. EPG will not refresh and update. Buzztv 6 not worth it! Same Streams on other apps working fine. Go figure! Quote
nbs. Posted January 15 Posted January 15 Give buzz all your info so they can look at the issue 3 Quote
