Macman_ca Posted October 8, 2025 Posted October 8, 2025 I have both a micro SD card formatted through the buzz utilities and I also have a Kinston USB stick. I have tried setting both as the default. But some of my recordings get cut off, or only the fist 30 secs... just curious if anyone else has seen this issue? Quote
Emporium Posted October 8, 2025 Posted October 8, 2025 Keep in mind that the B5 is an entry level box and it only has USB2 ports (no USB3) so transfer speed would be limited. Also many of the cheaper kingston USB sticks are known to be very slow in write speeds, hence the cheap price. Recordings would be limited to low bitrate and assuning you are not doing much since the CPU is also entry level. If the stream get's interrupted or glitches a little, the recording will stop. Quote
Macman_ca Posted October 9, 2025 Author Posted October 9, 2025 @ryu for the current issues XC api. My plan is to replace it with the Buzz Tv Powerstation 6 -8 gig ram, hopefully this month. Thank you @emporium ! Quote
