Nick Posted August 9, 2025 Posted August 9, 2025 Hi all, I’m having a PVR issues on my Classic Anniversary Edition and wondering if anyone has come across this issue and has a solution or can point me to right direction. Device: Model: BuzzTV Classic Anniversary Edition Firmware: V20250412 BuzzTV-5 App: v5.0.946 Storage: Internal shared storage only (54 GB free), no external attached MAC provider Tried with a public m3u list as well Issue: Recordings can be scheduled and appear in the PVR schedule list. Also enabled one touch recording but same result. When the recording time comes, no actual file is saved, nothing appears in the recordings list and nothing in storage. Plenty of space available (54 GB free), also tried with an external usb, and reformatted another one and configured it as part of the internal storage. Same issue. I have a X5 SS as well and it seems to be functioning fine there. I also thought it was a server/provider issue but I tried a public m3u list that should have no blocks and it still did not work. I have tried the following: Cleared cache/data for BuzzTV Live TV app. Rebooted and power-cycled the box. Tested with both my MAC provider and a public, DRM free list. Tried instant recording and scheduled recording. Result: Scheduling works but PVR never writes a file. Questions: Is this a known bug in V20250412? Has anyone found a workaround? Should I try another player? Thanks for any insight and apologies if its been posted somewhere, I can delete and repost in the correct thread. Quote
Ryu Posted August 9, 2025 Posted August 9, 2025 while watching live tv press menu, then PVR, then PVR options, and see what's your recording storage location? Quote
Ryu Posted August 9, 2025 Posted August 9, 2025 also, from Home Screen go to settings, Apps, click on Buzz Tv 5, then scroll down to permissions, and make sure you allow for files. Quote
Nick Posted August 9, 2025 Author Posted August 9, 2025 For storage location, it says internal shared storage. When I clock on it, all it shows is one option "Internal shared storage" and the permission for files is allowed. I was trying to select a specific path for the recordings but see no way to select an actual folder. Quote
Ryu Posted August 9, 2025 Posted August 9, 2025 I guess factory reset your box then try again and see if that helps. Quote
nbs. Posted August 9, 2025 Posted August 9, 2025 You either record to internal and it will use default location or set up external on a usb or micro sd Quote
Nick Posted August 9, 2025 Author Posted August 9, 2025 How do I find the default location? It doesn't let me select a path. If I factory reset, will it give me the option to set a path/select a location? Quote
dishuser Posted August 10, 2025 Posted August 10, 2025 1 hour ago, Nick said: For storage location, it says internal shared storage. When I clock on it, all it shows is one option "Internal shared storage" and the permission for files is allowed. I was trying to select a specific path for the recordings but see no way to select an actual folder. use a file explorer app to find your recordings Quote
stdly Posted August 10, 2025 Posted August 10, 2025 3 hours ago, Nick said: How do I find the default location? It doesn't let me select a path. If I factory reset, will it give me the option to set a path/select a location? On live TV press the menu button select PVR then select PVR Options then recording Storage Location. Quote
dishuser Posted August 10, 2025 Posted August 10, 2025 13 minutes ago, stdly said: On live TV press the menu button select PVR then select PVR Options then recording Storage Location. they don't have an external drive hooked up so there's no need to do that Quote
Nick Posted August 10, 2025 Author Posted August 10, 2025 Thank you all, the factory reset did the trick. 2 Quote
