koolbear Posted August 4, 2025 Posted August 4, 2025 I had power station 6 for almost a year. When I turn on my box it doesn't go straight to the live channel a black screen with a white dot. Also they need to put group channel number . 1 Quote
Ryu Posted August 4, 2025 Posted August 4, 2025 why not post in P6 section? P6 has two app buzz5 and buzz6. for buzz6 while in the app press menu, settings, configuration, other settings, and change stat live tv on boot to ON. for buzz5 while in the app press menu, settings, configurations, toggle on where it says start live tv on boot. make sure you are using the HDMI cable that came with it. if yes. then reseat cable on both ends and also try a different hdmi port on your tv if possible. 2 Quote
nbs. Posted August 5, 2025 Posted August 5, 2025 You wait a year to post an issue which has worked from day 1? 2 Quote
koolbear Posted August 5, 2025 Author Posted August 5, 2025 No, start it happening on the last update. Quote
nbs. Posted August 5, 2025 Posted August 5, 2025 You wait a year to post an issue which has worked from day 1? See what happens when you leave out info? 2 Quote
