WhiteZombie Posted June 10, 2025 Posted June 10, 2025 Hello I noticed if I use the Primary player setting on the buzz tv classic box it tends to freeze more than Backup player... with backup player selected I cannot pause tv which is annoying.... Suggestions? Quote
dishuser Posted June 10, 2025 Posted June 10, 2025 1 hour ago, WhiteZombie said: Xc api try a different stream format 3 Quote
WhiteZombie Posted June 11, 2025 Author Posted June 11, 2025 2 hours ago, dishuser said: try a different stream format How would I go about doing that? AliExpress where I bought it from only offered it in that format. Plus it comes with all the guide data, VOD, etc... Quote
Emporium Posted June 11, 2025 Posted June 11, 2025 If you go to menu->settings->configuration (where you change the player options), and you scroll down, do you have an option for "Stream format" ? If so, experiment by changing that option. Quote
