smiley2069 Posted April 5, 2025 Posted April 5, 2025 Is it possible to make a template 6 power station for loading other 6 power station. I would be great for loading 5 of them with the same template.. And is there a way to used cloud base DVR on your network so all of the 6 power station would share from it. Thanks Smiley Quote
Emporium Posted April 6, 2025 Posted April 6, 2025 If in terms of template you mean a backup of every 3rd party app, NO. IF you mean in terms of backing up the BuzzTV servers, settings and favorites, then Yes. For your DVR request, the answer is NO. There is always this: https://stbtalk.com/topic/14151-buzztv6-application-wishlist-for-new-features-and-enhancements/ 3 Quote
smiley2069 Posted April 8, 2025 Author Posted April 8, 2025 Hi Emporium Yes, the server setting and favorites and channels line up. So each one looks the same under live channels and movies and series. And where do you same that on to a flash drive. Thank You Smiley 1 Quote
pugsycan Posted April 8, 2025 Posted April 8, 2025 45 minutes ago, smiley2069 said: Hi Emporium Yes, the server setting and favorites and channels line up. So each one looks the same under live channels and movies and series. And where do you same that on to a flash drive. Thank You Smiley Menu-settings -configuration - app settings-backup and restore 4 Quote
smiley2069 Posted April 8, 2025 Author Posted April 8, 2025 The 6 power station 16 g there is no Menu-settings -configuration - app settings-backup and restore. I went through all menus and server menus. Is there any other way to do this on this model? Thanks Smiley Quote
nbs. Posted April 8, 2025 Posted April 8, 2025 (edited) Did you hit menu button on remote? Whats firmware on your p6? Edited April 8, 2025 by nbs. Quote
pugsycan Posted April 9, 2025 Posted April 9, 2025 (edited) 23 minutes ago, smiley2069 said: The 6 power station 16 g there is no Menu-settings -configuration - app settings-backup and restore. I went through all menus and server menus. Is there any other way to do this on this model? Thanks Smiley In live tv hit menu button then do the thing Edited April 9, 2025 by pugsycan 1 Quote
