Have a little problem.
go to all apps, file browser, local disk, pictures, screen shots, your screen shot should be here.
click on hamburger button next to home button then click on screen shot you want to delete. after you select screen shot click on  button with pencil icon. and select delete. 🙂
Edited by Ryu
  • Thanks 1
No. I had on the app DB assistant you know it helps clean out the junk files . Somehow someway it took a screenshot of it. And every time I hit the back button for a split second I see that screen come up. I uninstalled the app. I'm going to install it again. Been using it for years. But like I said every time I hit the back button for a split second you see a screenshot of DB assistant. It's annoying.
go to settings/screen saver
disregard
Edited by nbs.
