Jean-Luc Posted October 13, 2024 Posted October 13, 2024 (edited) Is it possible to control 2 TV's with the PowerStation P6 remote... My P6 PowerStation is in my living room and turns off the living room TV when I click TV on the bt-500, but I have a splitter that splits the source signal from the buzztv to my bedroom TV as well. Just wondering if that is possible... Thank you... Edited October 13, 2024 by Jean-Luc Quote
Ryu Posted October 13, 2024 Posted October 13, 2024 if same brand should work. even diffrent brand as long they have same code should work. I have two Samsung and I program only one but I can turn off both. 1 Quote
Emporium Posted October 13, 2024 Posted October 13, 2024 Technically, I'd prefer one of the other remotes that have IR learn keys for that kind of stuff (IR100, IR200, BT100, BT200, BT250 and now the BT350). You can learn the Power keys from the various TVs and just assign them to the different keys. One TV directly on the TV Power key, one to the "Source" button, and even others if you have and want to the "tv vol + and -" buttons (since they are separate from the box volume). On the Smart remotes (BT300, BT400, BT500) not that simple. First instinct would be to try manually programming the remote to the second TV (assuming it is one of the main brands supported), and then use HDMI CEC to control the main TV. But the issues is that programming the remote to the second TV would also assign the Volume buttons. So short of being to same brands with same code for power button (like Ryu) mentioned, I don't think so. Quote
