TKlondon Posted September 20, 2024 Posted September 20, 2024 HI I have restarted and pwer cycled, but cant install the update after i click download and install. it just sits there with the status bar scrolling. is it just busy, or do i need to do something ? TK Quote
Emporium Posted September 20, 2024 Posted September 20, 2024 (edited) It does take some time to prep. When I took last update yesterday, it took a good 10 minutes to "prep".. Then it took quite a while downloading all the different parts. 10 minutes can feel like a really long time if you just sit there and look at it Just wait. If you give it plenty of time and it persists, then maybe try a hard reset. Edited September 20, 2024 by Emporium 2 Quote
TKlondon Posted September 20, 2024 Author Posted September 20, 2024 after 20 min it started downloading Typical !! Oh well next ill wait longer 3 Quote
Ryu Posted September 20, 2024 Posted September 20, 2024 1 hour ago, TKlondon said: after 20 min it started downloading Typical !! Oh well next ill wait longer that also depends on your speed. not saying you have slow speed lol Quote
dishuser Posted September 20, 2024 Posted September 20, 2024 37 minutes ago, Ryu said: that also depends on your speed. not saying you have slow speed lol firmware updates are large 1 Quote
Emporium Posted September 21, 2024 Posted September 21, 2024 1 hour ago, Ryu said: that also depends on your speed. not saying you have slow speed lol In some cases the longest part is not even the download itself. It is the "Preparing system update" stage which is before the download starts. This is a google thing. Even many older pixel phones did the same. Sometimes on Pixel phones to get them to "move on" you had to turn on airplane mode, let it fail, then disable airplane mode and try the update again. Don't know what causes it, and not sure if it is the A/B update method, but you just need to be patient and eventually it works. 1 Quote
Ryu Posted September 21, 2024 Posted September 21, 2024 15 minutes ago, Emporium said: In some cases the longest part is not even the download itself. It is the "Preparing system update" stage which is before the download starts. This is a google thing. Even many older pixel phones did the same. Sometimes on Pixel phones to get them to "move on" you had to turn on airplane mode, let it fail, then disable airplane mode and try the update again. Don't know what causes it, and not sure if it is the A/B update method, but you just need to be patient and eventually it works. exactly, patient is the key. I maybe wrong but I think it goes through file/software integrity check which takes longer especially you have huge firmware & software together. 2 Quote
