P6 Buzz6 not loading XC Servers
Hi guys, just noticed my P6 Buzz6 not loading (3) XC Servers. Channel Stream Error.
And the Guide defaults to True 4k Bloomberg channel. Does not matter what XC server is selected.
It does load a MAC Server (1) on P6 Buzz6.
My XRS4900 loads all the same XC servers properly.
Any ideas why?
Thanks, Mark7
3 minutes ago, Mark7 said:
3 different portals, none with /c at the end of the URL
Thanks
yes I know and things do get change on server sides. if I were you I would try that. first type url on your browser and if it loads just look at the complete url then copy that and try that way might help. 🙂
  • Thanks 1
7 minutes ago, Mark7 said:
I know it was working on the Labour Day weekend...
im not testing p6 yet but only reason im saying try url with /c or with port because you said it was working on labor day weekend and nbs said nothing has changed so it must be server side. 🙂
Edited by Ryu
  • Thanks 1
2 minutes ago, Mark7 said:
Okay, tried /c on all 3 different XC Servers on Buzz6, still doesn't work.
Thanks for the suggestion.
thank you. as nbs said please message allaboutbuzz 🙂
one more test lol 🙂
delete all xc api if possible on buzz6 and clear cache on buzz6 then try again 🙂
Okay, that took a while, Deleting took 2 minutes for each XC Server. Cleared Cache on Buzz6. Cache was at 660mb.
Put first URL in, and it connected, no changes in URL address.
Now for the 4 other servers.
 I did load 1 server into Buzz5 and it worked perfectly.
Will update after loading the rest of the servers, including the MAC server.
Thanks Ryu
  • Thanks 1
1 minute ago, razor07 said:
I have the same problem with my servers not loading, works on buzz5, and other players.
try to clear cache on buzz6 please.
  • Thanks 1
Okay, all 3 XC servers came back on line, after Deleting them all, and the Cache.
Reloaded, and now they are all working.
Now, trying the MAC server, on Buzz6
Will let you know how it goes.
Thank you, everyone for your help
awesome. good work bud 🙂
  • Thanks 1
Okay, the MAC server is working on Buzz6, but I had to disconnect the power to the P6 for it to work properly.
Not sure what caused that, but P6 with Buzz6, 3 XC servers, and 1 MAC is now working.
Thanks
Thanks
thank you for trying and feedback. glad all is good now. I would still let allaboutbuzz know hole thing for awareness please. 🙂
  • Thanks 1
