Carolina Gower Posted September 4, 2024 Posted September 4, 2024 plaease replace the barel power jack replace with USB C Powewr Delivery 45W BuzzTV PowerStation 6 - 8GB DDR4 (BLACK/BLACK) BuzzTV PowerStation 6 - 8GB DDR4 (GREEN/BLACK) BuzzTV PowerStation 6 - 16GB DDR4 (BLACK/BLACK) BuzzTV PowerStation 6 - 16GB DDR4 (GREEN/BLACK) 1 1 Quote
allaboutbuzz Posted September 4, 2024 Posted September 4, 2024 11 hours ago, Carolina Gower said: plaease replace the barel power jack replace with USB C Powewr Delivery 45W BuzzTV PowerStation 6 - 8GB DDR4 (BLACK/BLACK) BuzzTV PowerStation 6 - 8GB DDR4 (GREEN/BLACK) BuzzTV PowerStation 6 - 16GB DDR4 (BLACK/BLACK) BuzzTV PowerStation 6 - 16GB DDR4 (GREEN/BLACK) We have individual Colors for a reason 1 Per Version only. And we can't use USB-C. We already looked into that. Quote
Carolina Gower Posted September 6, 2024 Author Posted September 6, 2024 On 9/4/2024 at 12:51 PM, allaboutbuzz said: We have individual Colors for a reason 1 Per Version only. And we can't use USB-C. We already looked into that. really? 45 wats is enough for windows laptops that are more power hungery than a android box also not a fan of the orange colour ... and thats why i was asking about BuzzTV X5 AX-C being updated hopefuly to BuzzTV 6 OS 2 Quote
Emporium Posted September 6, 2024 Posted September 6, 2024 31 minutes ago, Carolina Gower said: really? 45 wats is enough for windows laptops that are more power hungery than a android box also not a fan of the orange colour ... and thats why i was asking about BuzzTV X5 AX-C being updated hopefuly to BuzzTV 6 OS At the moment there is no other box that is announced that will be retrofitted with BuzzTV 6. And just to clarify, BuzzTV 6 is not an OS, it is an application. The OS on the P6 is Android 13, just like the OS on the X5 AX-C is Android 11. The design issue for the power connector was taken. For whatever reason it was taken (technical, financial, mix of both, whatever...), it is done. Also, I don't know what ORANGE color you are referring to. So far on Buzz Web site, there are only 2 options (not even 4 like you mentioned in your first post). The 8GB model is (Black/Black) The 16GB model is (Green/Black) The only Buzz box I recall having any Orange was the xrs4900 (great box, still my daily driver). And you can't satisfy everyone for colors. Some people will like it, and others won't. 7 Quote
nbs. Posted September 6, 2024 Posted September 6, 2024 1 hour ago, Carolina Gower said: really? 45 wats is enough for windows laptops that are more power hungery than a android box also not a fan of the orange colour ... and thats why i was asking about BuzzTV X5 AX-C being updated hopefuly to BuzzTV 6 OS I don't see where he mentioned anything about wattage. He referenced usb-c 3 Quote
allaboutbuzz Posted September 6, 2024 Posted September 6, 2024 10 hours ago, Emporium said: At the moment there is no other box that is announced that will be retrofitted with BuzzTV 6. And just to clarify, BuzzTV 6 is not an OS, it is an application. The OS on the P6 is Android 13, just like the OS on the X5 AX-C is Android 11. The design issue for the power connector was taken. For whatever reason it was taken (technical, financial, mix of both, whatever...), it is done. Also, I don't know what ORANGE color you are referring to. So far on Buzz Web site, there are only 2 options (not even 4 like you mentioned in your first post). The 8GB model is (Black/Black) The 16GB model is (Green/Black) The only Buzz box I recall having any Orange was the xrs4900 (great box, still my daily driver). And you can't satisfy everyone for colors. Some people will like it, and others won't. I think they mean the X5-SS as being Orange Even though its Red. 2 Quote
Carolina Gower Posted September 9, 2024 Author Posted September 9, 2024 On 9/6/2024 at 11:28 AM, allaboutbuzz said: I think they mean the X5-SS as being Orange Even though its Red. im colour blind 2 1 Quote
allaboutbuzz Posted September 9, 2024 Posted September 9, 2024 1 hour ago, Carolina Gower said: im colour blind Ok no problem I was just re confirming which model # you were referring 1 Quote
