Elie Posted November 2, 2024 Posted November 2, 2024 Hello We would like to see and it is nice to ad for buzztv 6 EPG server because it is no option in buzztv6 to change EPG to server only in buzztv 5 thanks 1 1 Quote
Emporium Posted November 2, 2024 Posted November 2, 2024 36 minutes ago, Elie said: Hello We would like to see and it is nice to ad for buzztv 6 EPG server because it is no option in buzztv6 to change EPG to server only in buzztv 5 thanks As mentioned in the other thread: Quote The P6 currently uses Server EPG on XC Username and Password only We will add XML support soon And confirmed 3 posts below that again: "Buzz 6 only uses Server EPG right now" It is XML that is not there and will be added. 2 Quote
dishuser Posted November 2, 2024 Posted November 2, 2024 3 hours ago, Elie said: Hello We would like to see and it is nice to ad for buzztv 6 EPG server because it is no option in buzztv6 to change EPG to server only in buzztv 5 thanks are you serious? this isn't isn't the first time you requested something after being told IT WILL BE ADDED!!! 1 1 Quote
Elie Posted November 20, 2024 Posted November 20, 2024 it is Nice to see in the Future update picture in picture Quote
Woody Posted December 5, 2024 Posted December 5, 2024 Group channel numbering and ability to arrang channels how we want in favorites .. theme as well 1 Quote
pugsycan Posted December 5, 2024 Posted December 5, 2024 1 hour ago, Woody said: Group channel numbering and ability to arrang channels how we want in favorites .. theme as well You can. In fav group press green the options are all there 2 Quote
Woody Posted December 6, 2024 Posted December 6, 2024 no u can only do by number by name or postion that they are in cant rearrange or move them to ifferent positions like u can in buzz tv 5 Quote
Emporium Posted December 12, 2024 Posted December 12, 2024 Future Feature Request: Mounting and RECORDING/DOWNLOADING to an network shared folder One nice thing to see would be the option to mount an SMB or NFS share (like on a NAS) and use that as a destination for Recordings/Downloads. Also, if in the same directory or subdirectory it can include whatever file (xml or whatever...) is needed to be able to get the show info (show name, epg description if there was any, channel, etc..). That way if you have more than one Buzz box, they can point to the same directory, and everyone can share everyone's recordings/downloads. A huge bonus would be to also have the filenames something more informative (like first 20 characters of show description, followed by date/time of recording). That way when you look at the directory, you have a good idea of what the media files are. Right now, they look like random names, but I am sure it has something to do with the stream URL. Thanks. 6 Quote
Blackmagic Posted February 11 Posted February 11 Will you be adding a Cloud Recording feature for the Powerstation to be able to record to the Powerstation and connect other BuzzTV Boxes in the house to can record to and watch from like a NVR? Example house has 5 BuzzTV Boxes and want to record in 1 BuzzTV Box and want to watch later the recording on another BuzzTV Box? Quote
Tony 62 Posted February 20 Posted February 20 Customize the EPG for live TV as you can with the BUZZ 5 and other player apps ... Quote
dishuser Posted February 20 Posted February 20 26 minutes ago, Tony 62 said: Customize the EPG for live TV as you can with the BUZZ 5 and other player apps ... do you even have a powerstation? Quote
Tony 62 Posted February 20 Posted February 20 1 hour ago, dishuser said: do you even have a powerstation? since launch .. do you ? Quote
allaboutbuzz Posted February 20 Posted February 20 3 hours ago, Tony 62 said: Customize the EPG for live TV as you can with the BUZZ 5 and other player apps ... Im assuming you mean themes? Quote
Tony 62 Posted February 20 Posted February 20 2 minutes ago, allaboutbuzz said: Im assuming you mean themes? Yes sir Quote
allaboutbuzz Posted February 20 Posted February 20 27 minutes ago, Tony 62 said: Yes sir Yes it will get added soon 2 Quote
Tony 62 Posted February 20 Posted February 20 3 minutes ago, allaboutbuzz said: Yes it will get added soon Thank you for your response sir ... Quote
dishuser Posted February 20 Posted February 20 2 hours ago, Tony 62 said: since launch .. do you ? even longer 1 Quote
Tony 62 Posted February 20 Posted February 20 1 minute ago, dishuser said: even longer good for you Quote
dishuser Posted February 20 Posted February 20 (edited) 3 minutes ago, Tony 62 said: good for you I was just making sure because some members with the L1 think this thread applies to them Edited February 20 by dishuser Quote
Tony 62 Posted February 20 Posted February 20 3 minutes ago, dishuser said: I was just making sure because some members with the L1 think this thread applies to them Cheers 1 Quote
Elie Posted March 16 Posted March 16 Hello it is possible to ad in VOD and TV series to be able to check the video quality when we press the info button ? Quote
Emporium Posted March 16 Posted March 16 48 minutes ago, Elie said: Hello it is possible to ad in VOD and TV series to be able to check the video quality when we press the info button ? That info is NOT in the movie list provided by the service as far as I know. So short of downloading/playing part of EVERY single VOD, that would not be possible I'm sure. Even the movie info/summary is pulled from tmdb/imdb, depending on the movie titles. So no real way of knowing what version/resolution/quality the file being served by a service is. Quote
dishuser Posted March 16 Posted March 16 49 minutes ago, Emporium said: That info is NOT in the movie list provided by the service as far as I know. So short of downloading/playing part of EVERY single VOD, that would not be possible I'm sure. Even the movie info/summary is pulled from tmdb/imdb, depending on the movie titles. So no real way of knowing what version/resolution/quality the file being served by a service is. when watching it info brings that up Quote
