allaboutbuzz Posted August 21, 2024 Posted August 21, 2024 On 8/21/2024 at 5:18 PM, Jeffrags said: when i go tt CHECK UPDATES i am shown that screen in the pic that shows buzztv5 software Expand Then you are following the instructions wrong Quote
Jeffrags Posted August 21, 2024 Posted August 21, 2024 On 8/21/2024 at 5:20 PM, allaboutbuzz said: Then you are following the instructions wrong Expand i go to the very top where it says search, home, livetv, VOD and apps then over one more to get the settings/server setting box, I go down to UPDATES and I am taken to the screen in the pic.......your system is up to date, where it shows.....current IPTV version 5.0.915 Quote
allaboutbuzz Posted August 21, 2024 Posted August 21, 2024 On 8/21/2024 at 5:20 PM, allaboutbuzz said: Then you are following the instructions wrong Expand The instructions state this. You will be prompted for the update automatically. Or you can check manually when in Live TV, pressing Menu>Settings>Check Update I attached a Video to show you what I mean. PXL_20240821_172426647.TS.mp4 2 Quote
nbs. Posted August 21, 2024 Posted August 21, 2024 On 8/21/2024 at 5:20 PM, Jeffrags said: i appreciate you alls help here but i think the box is fooked. lol Expand Then do a pin reset 1 Quote
allaboutbuzz Posted August 21, 2024 Posted August 21, 2024 On 8/21/2024 at 5:25 PM, Jeffrags said: i go to the very top where it says search, home, livetv, VOD and apps then over one more to get the settings/server setting box, I go down to UPDATES and I am taken to the screen in the pic.......your system is up to date, where it shows.....current IPTV version 5.0.915 Expand This is where we send Firmware Updates The Video I uploaded is where we send App updates These 2 things are separate. Sorry for the confusion. Quote
Jeffrags Posted August 21, 2024 Posted August 21, 2024 On 8/21/2024 at 5:26 PM, allaboutbuzz said: The instructions state this. You will be prompted for the update automatically. Or you can check manually when in Live TV, pressing Menu>Settings>Check Update I attached a Video to show you what I mean. PXL_20240821_172426647.TS.mp4Fetching info... Expand thanks for but when i check updates there I get...could not load application updates the first time I tried now it says there are no updates. Quote
Jeffrags Posted August 21, 2024 Posted August 21, 2024 On 8/21/2024 at 5:28 PM, allaboutbuzz said: This is where we send Firmware Updates The Video I uploaded is where we send App updates These 2 things are separate. Sorry for the confusion. Expand no worries, yes i was confused but again, no updates it says Quote
Emporium Posted August 21, 2024 Posted August 21, 2024 So CHANGE your home screen to BuzzTV 6... Not modern or anything else. Then launch LiveTV app.. And from the LiveTV app, press "menu" and see on bottom left, what is written for version. If you are at 1.0.16 or 1.0.17 then the message is correct.. Quote
Jeffrags Posted August 21, 2024 Posted August 21, 2024 On 8/21/2024 at 5:42 PM, Emporium said: So CHANGE your home screen to BuzzTV 6... Not modern or anything else. Then launch LiveTV app.. And from the LiveTV app, press "menu" and see on bottom left, what is written for version. If you are at 1.0.16 or 1.0.17 then the message is correct.. Expand it is on the buzztv6 home screen Quote
allaboutbuzz Posted August 21, 2024 Posted August 21, 2024 On 8/21/2024 at 5:41 PM, Jeffrags said: no worries, yes i was confused but again, no updates it says Expand What is the version # on the Main Menu on your unit I attached a photo Quote
Emporium Posted August 21, 2024 Posted August 21, 2024 (edited) On 8/21/2024 at 5:44 PM, Jeffrags said: it is on the buzztv6 home screen Expand OK.. Because the picture you posted on your FIRST posting, was NOT on buzztv 6 home screen. You were on ""BuzzTV Media Player 2" home screen theme. BTW: Does hitting the "GUIDE" button on your remote, take you to the EPG guide ? Assuming you have a server even defined. If you get a server screen, then buzztv 6 is still not configured. The server screen for Buzztv 6 is separate from the server screen of buzztv 5. Edited August 21, 2024 by Emporium Quote
Jeffrags Posted August 21, 2024 Posted August 21, 2024 On 8/21/2024 at 5:48 PM, allaboutbuzz said: What is the version # on the Main Menu on your unit I attached a photo Expand same as in ur pic, so that seems fine, dunno why I am getting the errors and on the main update page (as shown in the pic) that its diff now...who knows. Quote
Jeffrags Posted August 21, 2024 Posted August 21, 2024 On 8/21/2024 at 5:50 PM, Emporium said: OK.. Because the picture you posted on your FIRST posting, was NOT on buzztv 6 home screen. You were on ""BuzzTV Media Player 2" home screen theme. BTW: Does hitting the "GUIDE" button on your remote, take you to the EPG guide ? Assuming you have a server even defined. If you get a server screen, then buzztv 6 is still not configured. The server screen for Buzztv 6 is separate from the server screen of buzztv 5. Expand yeah i was messing around to see diff launchers ( this is super limited to stick launchers) and in media player 2 under update I got that error msg, that is why I showed it. and yes when I hit guide button the guide comes up, its one button that does work properly lol back button when in iptv doesn't take u out of IPTV at all, this box seem geared towards IPTV and not android usze Quote
allaboutbuzz Posted August 21, 2024 Posted August 21, 2024 On 8/21/2024 at 5:50 PM, Jeffrags said: same as in ur pic, so that seems fine, dunno why I am getting the errors and on the main update page (as shown in the pic) that its diff now...who knows. Expand So that would be why you get no updates available Because V1.0.17 is the latest update available for the Buzz 6 app. Same with the Firmware Which is 20240816 1 Quote
allaboutbuzz Posted August 21, 2024 Posted August 21, 2024 On 8/21/2024 at 5:50 PM, Jeffrags said: same as in ur pic, so that seems fine, dunno why I am getting the errors and on the main update page (as shown in the pic) that its diff now...who knows. Expand What errors are you referring to? Quote
Jeffrags Posted August 21, 2024 Posted August 21, 2024 On 8/21/2024 at 6:04 PM, allaboutbuzz said: What errors are you referring to? Expand when i did the hard reset Quote
allaboutbuzz Posted August 21, 2024 Posted August 21, 2024 On 8/21/2024 at 6:08 PM, Jeffrags said: when i did the hard reset Expand Ok not sure But everything else works now? Quote
Jeffrags Posted August 21, 2024 Posted August 21, 2024 On 8/21/2024 at 6:11 PM, allaboutbuzz said: Ok not sure But everything else works now? Expand some things work, some dont. some buttons work, some don't, cant control my surround sound with the remote, so I pretty much have to sue 3 remotes if I want to use this box where my other box its all done with one remote, some options in settings don't work, time is stuck on the 24 hr clock, cant change it to the 12 hr clock, location on screen is in same province but wrong city, a lot of tiny things that makes its not a good box really.....unfortunately, I was really looking forward to this box Quote
allaboutbuzz Posted August 21, 2024 Posted August 21, 2024 On 8/21/2024 at 6:18 PM, Jeffrags said: some things work, some dont. some buttons work, some don't, cant control my surround sound with the remote, so I pretty much have to sue 3 remotes if I want to use this box where my other box its all done with one remote, some options in settings don't work, time is stuck on the 24 hr clock, cant change it to the 12 hr clock, location on screen is in same province but wrong city, a lot of tiny things that makes its not a good box really.....unfortunately, I was really looking forward to this box Expand We will fix the 24/12 h time in an update. Will look into the Weather. What surround sound system and button controls are you referring to exactly? And you mentioned some buttons don't work? Which ones exactly and what apps are you trying them on. Quote
nbs. Posted August 21, 2024 Posted August 21, 2024 On 8/21/2024 at 5:20 PM, Jeffrags said: Expand I believe the issue is with the weather app itself as it is showing wrong location on other buzz boxes too for me Quote
Jeffrags Posted August 21, 2024 Posted August 21, 2024 On 8/21/2024 at 6:40 PM, allaboutbuzz said: We will fix the 24/12 h time in an update. Will look into the Weather. What surround sound system and button controls are you referring to exactly? And you mentioned some buttons don't work? Which ones exactly and what apps are you trying them on. Expand ok well with my other box the one remote works it all, wakes the tv when the box wakes up, controls my amp volume, etc, its an rca amp for my surround sound system. For an android box this one seems like its mainly geared towards iptv, most android boxes aren't so geared towards that but that's not a biggie, really....when u go to settings, device pref, decode and bitstream, u can not change the audio device to HDMI passthrough so it stays on it, it always goes back to decode. if I pair the remote to work my tv. i have no volume control at all using the remote. so I have to use one remote to turn the tv on and off, one for the box, and one for the surround sound amp. The one remote should work it all. the HDIM-CEC section in settings the audio control wont work unless I pair the tv to it and then it doesn't work cause of the surround system set up. the audio amplifier control doesn't do a thing. from what ppl are saying you are locked into the default launchers that come with the box, u can not add any outside launchers at all, this is turning a lot of ppl off from what I have heard, bothers me also as I don't care for the default launchers , would be nice if when u click on live tv, you could use the app you want and not have to use the default buzztv app, also when in iptv, watching something, and u hit the back button, on most devices if u keep hitting it it take u right out of what u are in and back to the home screen, this one doesn't, just goes from ur tv screen to the semi guideand back and forth, you have to hit the home button then down to button 5 to get out of the app, real pain in the butt to have to do this every time. i accidently hit the pause button on the remote and now cant get iptv to play again lol. gonna have to unplug and replug again.... Quote
Jeffrags Posted August 21, 2024 Posted August 21, 2024 On 8/21/2024 at 6:40 PM, allaboutbuzz said: We will fix the 24/12 h time in an update. Will look into the Weather. What surround sound system and button controls are you referring to exactly? And you mentioned some buttons don't work? Which ones exactly and what apps are you trying them on. Expand am curious, when you go to all apps, and click on the dbl down arrow box, what does your screen look like? Quote
nbs. Posted August 21, 2024 Posted August 21, 2024 On 8/21/2024 at 7:17 PM, Jeffrags said: am curious, when you go to all apps, and click on the dbl down arrow box, what does your screen look like? Expand It'd be easier if you posted a pic Quote
Jeffrags Posted August 21, 2024 Posted August 21, 2024 On 8/21/2024 at 7:34 PM, nbs. said: It'd be easier if you posted a pic Expand i have, its this image, hence why I wanted to see yours Quote
Emporium Posted August 21, 2024 Posted August 21, 2024 On 8/21/2024 at 7:38 PM, Jeffrags said: i have, its this image, hence why I wanted to see yours Expand That is identical to mine. Only difference, mine has a little bit of "release notes" history on the left, since mine was updated to that. In your case, you did a reset, so some of that was already there. Quote
