Chris1 Posted July 18, 2024 Posted July 18, 2024 Hopefully next week I ordered my the second it was available to pre ordered Quote
DRAG00N519 Posted July 18, 2024 Posted July 18, 2024 On 7/18/2024 at 4:35 AM, dishuser said: there's plenty of good exteral drives out there for less Expand I was thinking there were probably cheaper options available but a friend recommended that particular SSD end it was also the one I seen when scrolling through the pictures for the power station so I figured why not go with that one because I know it's compatible with the device 1 Quote
TonyC Posted August 3, 2024 Author Posted August 3, 2024 Hi All, I believe the Powerstation is available very soon, would there be any possibility of sharing images of 'server settings' and how to load portal. Many Thanks Quote
dishuser Posted August 3, 2024 Posted August 3, 2024 On 8/3/2024 at 12:21 PM, TonyC said: Same as the xrs 4900? Expand all are the same for server settings 1 Quote
Emporium Posted August 3, 2024 Posted August 3, 2024 On 8/3/2024 at 12:21 PM, TonyC said: Same as the xrs 4900? Expand The 4900 never had buzztv 2 But the truth is, since buzztv 2 the options have not changed that much. On Buzztv 2, you had a certain number of "slots" available (I think it was 13), and you had only 3 reserved for M3U lists. As of BuzzTV 4 (which has carried over to BuzzTV 5) it changed and you have 3 separate options (MAC/XC/M3U) and you can add as many server entries as you want in each sub type. And in a recent update (few months ago), they added back the option to be able to change MAC on BuzzTV 5. BuzzTV 6, there is rumour that you may have more than one server active at the same time (similar to another popular software), but since no one has seen it yet (at least not anyone who is not bound by any NDA), it is hard to provide details. If they shipped yesterday, then people should start receiving them this coming week. Not sure if they will have buzztv 6 or if buzztv6 will be an OTA update, but I guess we'll find out soon enough. Quote
dishuser Posted August 3, 2024 Posted August 3, 2024 changing mac happened last year the power station comes with buzztv 6 hence the code name p6 3 Quote
nbs. Posted August 7, 2024 Posted August 7, 2024 Server setup is different and will be changing as box gets update 2 Quote
TonyC Posted August 8, 2024 Author Posted August 8, 2024 Hi NBS, How will it change? Many Thanks Quote
nbs. Posted August 8, 2024 Posted August 8, 2024 It's not how they want it right now but they don't wish to hold things up I'm not at liberty to discuss finished product Sorry 2 Quote
TonyC Posted August 8, 2024 Author Posted August 8, 2024 Will it be as user friendly as it is currently? Quote
TonyC Posted August 8, 2024 Author Posted August 8, 2024 Thank you, and thanks for the screenshots. 1 Quote
allaboutbuzz Posted August 8, 2024 Posted August 8, 2024 On 8/8/2024 at 3:05 PM, TonyC said: Hi NBS, How will it change? Many Thanks Expand Its already changed, we had a different UI on an internal pre release So we changed it based on feedback and its ready to go right now for the release 4 Quote
