Was working fine. Next day, no audio or video. Connects to portal, loads epg, then nothing. Keep getting media formats not supported. I've switched between both primary and backup players, same results. Pulled power, ethernet cable, HDMI cable, then restart, same results. Even rebooted my router. VOD, same thing.
Any ideas what's going on ?
Thanks
MAC server or XC ?
If it is MAC based server, then I recommend asking your reseller to do a MAC reset on your account.
Do other apps like Youtube work ?
From the Updates screen, what is your Firmware and Software versions ?
XC.
Youtube works fine.
Did a factory reset last nite, still same problems.
Firmware V20240202
IPTV Version 5.0.935
thanks
32 minutes ago, kdk said:
also, I have a friend running ****** but with a Formuler box. They are not having any problems.
thanks
read the rules
just because someone else has it working means squat
did you try your account on a 3rd party app?
sorry didn't know I was breaking any rules, new to this
and I don't know what you mean by a 3rd party app, would you enlighten me ?
