Bucko Posted February 19, 2024 Posted February 19, 2024 Some apps are not available to download because not available in my region, not good, thanks Quote
dishuser Posted February 19, 2024 Posted February 19, 2024 what does that have to do with buzztv 5(an app)? try a vpn 1 Quote
Bucko Posted February 19, 2024 Author Posted February 19, 2024 Your box has wifi location service and will not engage for location to download apps from different regions like I am in Canada and your box tells me cannot download apps because wrong region, probabley google service doing this.I have a vpn. Quote
gig63 Posted February 19, 2024 Posted February 19, 2024 That is not a Buzz problem that is your VPN problem turn it off and and download your apps or change location closer to you 1 Quote
Ryu Posted February 19, 2024 Posted February 19, 2024 2 hours ago, Bucko said: Your box has wifi location service and will not engage for location to download apps from different regions like I am in Canada and your box tells me cannot download apps because wrong region, probabley google service doing this.I have a vpn. use aptoide or side load. your box is open and willing to take however you like to transfer/install. Quote
Emporium Posted February 19, 2024 Posted February 19, 2024 From main menu, if you go into settings, and select "location" you can turn it on if you want. I just don't see the point. Use Aptoide store (as mentioned by Ryu), or sideload anything you want. I'm in Canada also, and have no issue installing any app so far. 2 Quote
dishuser Posted February 19, 2024 Posted February 19, 2024 I've used a vpn and downloaded/installed apps without any issue Quote
