Dolfan Posted January 3, 2024 Posted January 3, 2024 Hello, when I go to VOD to select a tv show, no episodes show. They eventually came up yesterday, but no they haven’t shown all day today. Movies work, but episodes in TV series are not there. The box is updated to the latest version. I’ve exited and reloaded channels. Not sure what else to do. Thanks! Quote
nbs. Posted January 3, 2024 Posted January 3, 2024 (edited) Have you tried the other player? Contact your service see if they are having issues Edited January 3, 2024 by nbs. Quote
Emporium Posted January 3, 2024 Posted January 3, 2024 Have you tried using another app (like smarters or stbemu), just to ensure it is not your provider ? Also, are these shows you have tagged as favorite or are you searching from them clean ? Favorites can go "Stale" if the provider changes enough in the list (ie: servers, links, etc..). Quote
Dolfan Posted January 3, 2024 Author Posted January 3, 2024 Thanks for the ideas - I’m very new to this, not sure how I would change the player? yes, these are tv shows in my favourites. I’ve tried searching for the same show after removing it from my favourites and it still didn’t work. it comes and goes though - some days they’re there and it can go almost a week with the episode showing up. Quote
Emporium Posted January 4, 2024 Posted January 4, 2024 Maybe their server is overloaded and when your box tries to populate it and get's no response. Checking with another app, will give you some sort of confirmation at least. Favourites I often only tag for temporary use. And if they eventually get to a point that I see no episodes, I just remove the favorite and re-search and it typically is fine again for a while until server reshuffles links/redirects. Quote
Dolfan Posted January 4, 2024 Author Posted January 4, 2024 Cool. I’ll give it a shot… I’ll check in with the provider if that doesn’t work. Thanks for the ideas! Quote
nbs. Posted January 4, 2024 Posted January 4, 2024 2 hours ago, Dolfan said: Thanks for the ideas - I’m very new to this, not sure how I would change the player? yes, these are tv shows in my favourites. I’ve tried searching for the same show after removing it from my favourites and it still didn’t work. it comes and goes though - some days they’re there and it can go almost a week with the episode showing up. Menu ,settings, config highlight vod,tv and change player 3 Quote
Emporium Posted January 4, 2024 Posted January 4, 2024 When you so "no episodes show", I assume you mean that you see the TV series in question, but when you go into it, the only option you have is "possibly" to see a trailer and that's it ? No seasons or episodes available to select ? OR Do you actually see everything there, but when you select them, they don't play ? Quote
Dolfan Posted January 4, 2024 Author Posted January 4, 2024 Yes, I see the series icon. When I click the series there is nothing to play. None of the episodes show up, just the icon. Quote
dishuser Posted January 4, 2024 Posted January 4, 2024 sounds like a problem on service side you don't mention model used as well as firmware and software versions and posting latest update is installed is pointless 1 Quote
Dolfan Posted January 4, 2024 Author Posted January 4, 2024 It’s the E5 Version 5.0.799 Firmware V20230324 Quote
dishuser Posted January 5, 2024 Posted January 5, 2024 like I posted before I believe it's on service end also when in live tv have you checked for updates? 1 Quote
Dolfan Posted January 5, 2024 Author Posted January 5, 2024 Are you saying when watching live tv - click menu and check for update there? Yes, no updates available I have to wait for bro-in law to return from vacation to check with provider, he got me the box. lately, when I go into a series in VOD it’s still blank. I recently left the tv in the blank series, when I came back awhile later the episodes were loaded. Since then I tested and if I stay in the blank series the episodes eventually load. Maybe after 5-10 minutes. My internet connection is about 350mbs - I assume that confirms it’s a provider issue? Quote
mumik08 Posted January 1, 2025 Posted January 1, 2025 On 1/5/2024 at 9:41 AM, Dolfan said: Are you saying when watching live tv - click menu and check for update there? Yes, no updates available I have to wait for bro-in law to return from vacation to check with provider, he got me the box. lately, when I go into a series in VOD it’s still blank. I recently left the tv in the blank series, when I came back awhile later the episodes were loaded. Since then I tested and if I stay in the blank series the episodes eventually load. Maybe after 5-10 minutes. My internet connection is about 350mbs - I assume that confirms it’s a provider issue? Did you find a way to fix it? I have the same issue Quote
dishuser Posted January 1, 2025 Posted January 1, 2025 14 minutes ago, mumik08 said: Did you find a way to fix it? I have the same issue did you try a 3rd party iptv app to confirm it's not the service you use? 2 Quote
kr16 Posted January 27, 2025 Posted January 27, 2025 I have the same issue with BuzzTV as well. Everything is OK, liveTV, VOD, but under TVSeries there is nothing. I installed Tivimate and I can see all the Shows - so on the provider side everything seems to be OK. As far as the player I changed from something like Configured to Default but it does not make any difference. Quote
dishuser Posted January 27, 2025 Posted January 27, 2025 1 hour ago, kr16 said: I have the same issue with BuzzTV as well. Everything is OK, liveTV, VOD, but under TVSeries there is nothing. I installed Tivimate and I can see all the Shows - so on the provider side everything seems to be OK. As far as the player I changed from something like Configured to Default but it does not make any difference. maybe the tv series are in vod Quote
Emporium Posted January 28, 2025 Posted January 28, 2025 What buzztv box model ? And what firmware and software version is installed (should be able to see from the updates screen) ? Quote
kr16 Posted January 28, 2025 Posted January 28, 2025 XRS4000 firmware V20211111 iptv ver. 4.0.530 Quote
dishuser Posted January 28, 2025 Posted January 28, 2025 37 minutes ago, kr16 said: XRS4000 firmware V20211111 iptv ver. 4.0.530 wow that's old go to updates screen and after checking for an update enter 2015 with remote 1 Quote
Emporium Posted January 28, 2025 Posted January 28, 2025 Do what DU mentioned and it will bring you into 2025 But be patient, it will update and then after the reboot, it will probably update another 1 or 2 times. But it's be worth it. Quote
kr16 Posted January 28, 2025 Posted January 28, 2025 2015 gives me No Beta Update Available I tried different combinations (assuming 2015 is a year) but it didn't do anything. Is there a way to load the firmware from USB ? thx Quote
dishuser Posted January 28, 2025 Posted January 28, 2025 12 minutes ago, kr16 said: 2015 gives me No Beta Update Available I tried different combinations (assuming 2015 is a year) but it didn't do anything. Is there a way to load the firmware from USB ? thx email cs@buzztv.com with model and mac Quote
