jeepersmr Posted December 22, 2023 Posted December 22, 2023 I had to do a reset of my st-4000 vidstick and its asking to pair and it will not pair n using the OK and vol down buttons. the screen says SEARCHING...and never pairs. the LED is flashing red and the IR is connected. just wont pair. is there any way around this bluetooth pairing? Quote
nbs. Posted December 22, 2023 Posted December 22, 2023 Do you have the ir sensor so you can use ir? 1 Quote
Ryu Posted December 22, 2023 Posted December 22, 2023 use IR to go to settings and remote and accessories, and see theres option to add accessories and try from there and see if that helps. Quote
dishuser Posted December 22, 2023 Posted December 22, 2023 I've always got close to stick to pair Quote
