sea157 Posted November 7, 2023 Posted November 7, 2023 Has anyone had any luck at installing the Peacock apk on there U5 box? If you did could you tell me how you did it? Quote
sea157 Posted November 7, 2023 Author Posted November 7, 2023 4 hours ago, nbs. said: Â My Peacock works perfect on my XRS4500 boxes running Buzztv 5 but it will not work on my U5 box. Any help appreciated to get it installed and working on my U5 box. Quote
Emporium Posted November 8, 2023 Posted November 8, 2023 I just installed the latest version 4.10.23, and installation works without an issue. However, peacock has decided to limit the app to a very small number of "compatible" boxes. So when it starts it just give the dumb message that "Sorry, Peacock is unavailable on this device. Please see we-are-idiots.com for supported devices". The issue is peacock's narrow minded corporate thinking. Unlike netflix which will work, with some restrictions, if not on an "approved" box, this app just doesn't work at all.    2 Quote
sea157 Posted November 8, 2023 Author Posted November 8, 2023 1 hour ago, Emporium said: I just installed the latest version 4.10.23, and installation works without an issue. However, peacock has decided to limit the app to a very small number of "compatible" boxes. So when it starts it just give the dumb message that "Sorry, Peacock is unavailable on this device. Please see we-are-idiots.com for supported devices". The issue is peacock's narrow minded corporate thinking. Unlike netflix which will work, with some restrictions, if not on an "approved" box, this app just doesn't work at all.    Yes that is the same message I get "Sorry, Peacock is unavailable on this device" I was hoping someone may have a work around for this but I guess not yet. Quote
dishuser Posted November 8, 2023 Posted November 8, 2023 what version are you using? maybe try the mobile version Quote
sea157 Posted November 8, 2023 Author Posted November 8, 2023 13 hours ago, dishuser said: what version are you using? maybe try the mobile version Nope no luck on the U5, I give up. Quote
nbs. Posted November 8, 2023 Posted November 8, 2023 2 hours ago, sea157 said: Nope no luck on the U5, I give up. Complain to peacock 1 Quote
dishuser Posted November 8, 2023 Posted November 8, 2023 peacock is just shooting themselves in the foot most streaming services do 1 Quote
Emporium Posted November 9, 2023 Posted November 9, 2023 (edited) OK.. So you can download and give this version a try: https://www.apkmirror.com/apk/peacock-tv-llc/peacock-tv-android-tv/peacock-tv-android-tv-1-11-6-release/peacock-tv-stream-tv-movies-android-tv-1-11-6-android-apk-download/ I installed it on my U5, and unlike the version in Aptoide, this one installs, starts and you can go to login screen and even read all the "privacy and terms of use" links, and even try to connect using phone login. There is also this version which is designed for FireTV. Seems to be the same simlar to the version above, but posting both just in case. https://www.apkmirror.com/apk/peacock-tv-llc/peacock-tv-fire-tv-android-tv/peacock-tv-fire-tv-android-tv-1-11-6-release/peacock-tv-fire-tv-android-tv-1-11-6-android-apk-download/ I don't have a peacock account (and don't care for one) so I can't confirm that it logs in however. But you can click on the Sign In option and go to the sign in screen. The "choose a plan" option does not work (could b because of my VPN location) so just ensure to use a PC or other device to create a plan if you don't have one. And obviously, make sure you use a US VPN server.  Post back the results.  Edited November 9, 2023 by Emporium Quote
dishuser Posted November 9, 2023 Posted November 9, 2023 (edited) I already mentioned mobile version and they said it doesn't work and that version was released on the 2nd which I said to try it Edited November 9, 2023 by dishuser Quote
Emporium Posted November 9, 2023 Posted November 9, 2023 56 minutes ago, dishuser said: I already mentioned mobile version and they said it doesn't work and that version was released on the 2nd which I said to try it I know you did, but these are not mobile versions... They are for FireTV and for AndroidTV version. These versions definitely get past the usual internal check for compatibility however.  1 Quote
dishuser Posted November 9, 2023 Posted November 9, 2023 9 hours ago, Emporium said: I know you did, but these are not mobile versions... They are for FireTV and for AndroidTV version. These versions definitely get past the usual internal check for compatibility however.  same version for my samsung phone,android tv and fire tv 2 Quote
sea157 Posted November 9, 2023 Author Posted November 9, 2023 11 hours ago, Emporium said: OK.. So you can download and give this version a try: https://www.apkmirror.com/apk/peacock-tv-llc/peacock-tv-android-tv/peacock-tv-android-tv-1-11-6-release/peacock-tv-stream-tv-movies-android-tv-1-11-6-android-apk-download/ I installed it on my U5, and unlike the version in Aptoide, this one installs, starts and you can go to login screen and even read all the "privacy and terms of use" links, and even try to connect using phone login. There is also this version which is designed for FireTV. Seems to be the same simlar to the version above, but posting both just in case. https://www.apkmirror.com/apk/peacock-tv-llc/peacock-tv-fire-tv-android-tv/peacock-tv-fire-tv-android-tv-1-11-6-release/peacock-tv-fire-tv-android-tv-1-11-6-android-apk-download/ I don't have a peacock account (and don't care for one) so I can't confirm that it logs in however. But you can click on the Sign In option and go to the sign in screen. The "choose a plan" option does not work (could b because of my VPN location) so just ensure to use a PC or other device to create a plan if you don't have one. And obviously, make sure you use a US VPN server.  Post back the results.  Emporium, YOU ARE THE MAN!!! This one worked for me !! https://www.apkmirror.com/apk/peacock-tv-llc/peacock-tv-android-tv/peacock-tv-android-tv-1-11-6-release/peacock-tv-stream-tv-movies-android-tv-1-11-6-android-apk-download/ I not have Peacock installed and working perfect on my Buzztv U5 ! Thank you so much, you never cease to amaze me! 1 Quote
dishuser Posted November 9, 2023 Posted November 9, 2023 but you said it doesn't work when I said to try it...lol Quote
sea157 Posted November 9, 2023 Author Posted November 9, 2023 1 hour ago, dishuser said: but you said it doesn't work when I said to try it...lol Sorry dishuser, I must have downloaded the wrong version, because that version not work. The link to the version Emporium pointed me to worked like a charm. So if anyone needs the Peacock app that will work on a Buzztv U5 box this is the one they need. https://www.apkmirror.com/apk/peacock-tv-llc/peacock-tv-android-tv/peacock-tv-android-tv-1-11-6-release/peacock-tv-stream-tv-movies-android-tv-1-11-6-android-apk-download/ Thanks for all the help guys! Quote
dishuser Posted November 9, 2023 Posted November 9, 2023 the first hit(the one hilited) is that version Quote
