Mathew Hart Posted October 19, 2023 Posted October 19, 2023 Team, I have a new X5 128AI with the BT-400 remote, this remote seems very unstable, it's hit or miss whether it will work. 40% of the time it does not work and I have to log in to the X5 using Teamviewer and unpair and repair the remote, or restart the system via power cable. It also will be very sporadic and go crazy and scroll through things on its own while you're trying to go up or down through menus or guides it will just take off and do this. are there any tips or tricks to get this remote to be more stable? It's as upgraded as I can get it. Quote
Mathew Hart Posted October 21, 2023 Author Posted October 21, 2023 Team, anyone have any idea what the BT range is on this? this might be part of the issue, the other issue might be because i have the BuzzTV mounted on the back of the TV. thoughts? Quote
dishuser Posted October 21, 2023 Posted October 21, 2023 On 10/21/2023 at 3:54 PM, Mathew Hart said: Team, anyone have any idea what the BT range is on this? this might be part of the issue, the other issue might be because i have the BuzzTV mounted on the back of the TV. thoughts? Expand I can go into another room and mine still worx Quote
Mathew Hart Posted October 23, 2023 Author Posted October 23, 2023 I pulled it from behind and it works better, still have to be close or i have the same issues. Quote
Emporium Posted October 23, 2023 Posted October 23, 2023 And if you go into settings with Remote/accessories, it shows that the remote is connected ? In the image above it says "connecting" not "connected". the BT is not connected and you are using IR only on the remote. You may need to re-pair the remote. My basement is about 20ft long, and there are no issues at that distance. My box is on a small shelf on top of the TV. Quote
Mathew Hart Posted October 23, 2023 Author Posted October 23, 2023 Its connected and shows in the Bluetooth devices. but i found the IR works a little better. Quote
dishuser Posted October 23, 2023 Posted October 23, 2023 On 10/23/2023 at 5:53 PM, Mathew Hart said: Its connected and shows in the Bluetooth devices. but i found the IR works a little better. Expand did it show battery level when you clicked on bt400? Quote
nbs. Posted October 23, 2023 Posted October 23, 2023 On 10/23/2023 at 10:12 PM, dishuser said: did it show battery level when you clicked on bt400? Expand The picture shows 88 but it doesn't show connected,just connecting 2 Quote
Mathew Hart Posted October 24, 2023 Author Posted October 24, 2023 It did connect and showed a battery of 86%. 1 Quote
dishuser Posted October 24, 2023 Posted October 24, 2023 do you have any other bluetooth devices? Quote
