theres reset button on the side. hold it for 30 seconds. if that don't work then try turn off the box, hold the button and turn it on and keep holding until you see the recovery screen.
Thanks for the suggestions guys. I would totally go to the right and chose settings but again, its just a blue screen im stuck on with nothing on it. I followed the instructions to unplug the device and hold the reset button and it does go into recovery mode. However from here, the BT-400 remote does not work in this mode and the screen says no command. No luck lol.
do you have a pc keyboard to connect to it to see if that helps. if you do then turn off your box first, connect keyboard then turn on your box and see if that helps.
just curious have you ever reboot your box after you got stuck? if not then try to turn on your box now and see if that works now.
1 hour ago, thisisgillie said:
Thanks Ryu! I put it I'm recovery mode again and plugged a keyboard into the USB and was able to reset that way. Thanks.
your remote was in IR mode so all you had to do was get closer and point directy at the dongle
