BuzzTV Essentials E2 SE Specs
Output Resolution: 4K (3840 x 2160)
CPU : Amlogic S905X3 64-bit quad-core ARM® Cortex™ A55
GPU : G31™ MP2
RAM: 4GB
Storage: 32GB eMMC
Operating System: Android OS 9 Pie
WIFI: 2.4GHz / 5GHz Dual-Band 2X2 WIFI
LAN: Ethernet 10/100
BT: 5.0
Video decoder : 4K@60fps, VP9, H.265(HEVC) , H.264(AVC, MVC) , Real , MPEG1/2/4 ,
Video Format : TS , MKV , FLV , MOV , AVI , RM , MP4
Audio Format : MPEG-1 Layer 1,2 , AAC-LC , HE AAC V1
Image decoder : JPG , BMP , GIF , PNG
Support Language : Global
Length : 10.5cm
Width : 10.5cm
Thickness: 2cm
Color : Black
USB2.0 : 1
USB3.0 : 1
MicroSD: 1
Power Interface : 1
Optical Audio : 1
HDMI 2.0 (CEC) : 1
10/100 LAN : 1
Type : 5V 2 Amp Adapter
  • 4 months later...
6 minutes ago, KamalRattol said:
as soon as attached the device its checking for the updates than after 2% it says  you need to register with serial no some where ...but not getting that
email the info to cs@buzztv.com
Try rebooting  a few times
  • 2 months later...
We have e2 se .. we are trying to setup up remote to use to turn TV on and off.
Wife has followed instructions on the remote but no luck.
Can someone HELP
thks in advance
