TMN Posted May 19, 2021 Posted May 19, 2021 I got new buzzTV 4900 can't turn on stuck on the red light . I tried power on with remote control , but still have the same problem . please help ?                              Thanks 1 Quote
nbs. Posted May 19, 2021 Posted May 19, 2021 you can try this procedure and see it it helps Its the same procedure as the 4500 Otherwise you will have to email buzz or pm allaboutbuzz  cs@buzztv.com  Quote
TMN Posted May 19, 2021 Author Posted May 19, 2021 Thanks for reply . Unplug it and plug back still have the same problem Quote
dishuser Posted May 19, 2021 Posted May 19, 2021 41 minutes ago, TMN said: I am newbie . How to pm allaboutbuzz ? you click on username and select message https://stbtalk.com/index.php?/profile/200-allaboutbuzz/ but as nbs. asked did you try a reset? 1 Quote
Maestro701 Posted May 19, 2021 Posted May 19, 2021 Have you paired the remote control to the unit? Were you prompted to pair the remote to the device when you were setting it up for the first time? 1 Quote
allaboutbuzz Posted May 19, 2021 Posted May 19, 2021 19 hours ago, TMN said: I got new buzzTV 4900 can't turn on stuck on the red light . I tried power on with remote control , but still have the same problem . please help ?                              Thanks Were you dealing with back and forth over Ebay about this issue? If so, I think it was determined your power supply was the issue. 1 Quote
Maestro701 Posted May 19, 2021 Posted May 19, 2021 6 hours ago, nbs. said: Pretty hard to pair when it wont turn on? I was thinking that he had already got the unit working. But found himself in a situation where he goes to switch it on after it being off and it would start up. Quote
