BT-400 Remote IR code for Insignia Tv
Bill
  • 2 weeks later...
Not as far as I know.  The built in database is limited to some of the major TV manufacturer IR codes, as list in the manual (link a few posts up).  You can do a scan if you want to see if something is compatible.
Now, if things communicate via CEC (for volume and other minor options), that may be a YMMV on what it can or cannot control.    But that would not be via any IR and would not really require any programming of remote.
