DJ3024 Posted March 9, 2021 Share Posted March 9, 2021 Was watching a TV show and the show froze no big deal. Remote would not let me shut box off so I unplugged it waited a bit plugged it back in and it would not reboot. Tried again same thing. I used a toothpick and brought up the menu and tried a reboot but that failed as well. Box would only try to reboot. So I tried a soft or a hard reboot where you clear the data and that failed as well. At this point is my box as they use the term Bricked? Or is there something I could try? Thanks. Quote Link to comment Share on other sites More sharing options...
nbs. Posted March 9, 2021 Share Posted March 9, 2021 When you bring up the android recovery screen did you select wpe/reset Quote Link to comment Share on other sites More sharing options...
DJ3024 Posted March 9, 2021 Author Share Posted March 9, 2021 The first one I did was just a reboot system now and it just goes back to the logo and flashes in and out. Tried unplugging a few times that did not work. Then I did wpe/reset where it showed all the data cleared and to do a reboot now. Did the reboot now again and the same thing just the logo will appear. Quote Link to comment Share on other sites More sharing options...
nbs. Posted March 9, 2021 Share Posted March 9, 2021 Pm allaboutbuzz with your info 1 Quote Link to comment Share on other sites More sharing options...
DJ3024 Posted March 9, 2021 Author Share Posted March 9, 2021 Thanks:) will do. Quote Link to comment Share on other sites More sharing options...
